LD2655HD service menu
Hi i got something on screen that looks like a burn-in but the guy at the store said i should bring it over and the would do something so that it might go away but i have to pay to do that and all i need to do it myself is to know how to get in the service menu of the ProLine
LD2655HDWould be ever gratefull cause i aint got the money to repair or to buy a new one and i dont want to give away the tv to the store!
SOURCE: Curved red lines across screen
hi there, i had the exact same problem as you and this is how we solved it. Instead of replacing the convergence IC's as suggested above, which requires soldering and de-soldering, which could damage your board (this happeend to us). Order online part # SSB-5068A. This is the ENTIRE convergence board with new IC's. Cost you about $140 (from vance baldwin.com) but is a lot less hassle than you trying to soldering/desoldering parts. Only thing is, next to the 2 large heat sinks, there is this large silver component that you need to unscrew from your old board, and unplug and attach to your new board. We tok the new board..hooked up all the wires..and voila, no more convergence issues.
Posted on Jul 13, 2007
  • 13 Answers
SOURCE: jvc remote control
"i already paid for the tv so why pay for something that should be readely available to me in the first place I should have access to all the features on the tv ".. WRONG!!!!!!!!!You should have a warranty for this TV but it's old , anyway. First,receive a reference image (let's say CNN).Second:press "Sleep Timer" key and set the value to "0". Then press "Display" and "Video Status" keys at the same time. Third: use "Vol +/-" and " Channel +/-" to select "2.DEF(D)".Go to "D03: V.SIZE" and modify step by step the value for best fitting. There is also switch " SW401" on the main board for centering the image . Finally, press "EXIT" key till you exit the "Service Menu". Don't try to modify anything else!!!!!!!!!!!!!!!!!
Posted on Nov 20, 2007
ctf1800
  • 4402 Answers
SOURCE: RCA 52" Mdl P52939, PTK195S16B
but there are two
quick things you might be able to do. If it is a PTK195 you can most
likely install the updated power supply board. If you can solder and
know safety (like discharging caps) you can update the PS chip from an
STK730-??? to an STK730-180 (IIRC). I found that simply replacing the
chip with an equivalent fails most of the time. The 180s seem to hold
up.
Posted on Dec 19, 2007
SOURCE: HDMI input failure
Hey guys, had the same problem. Found this solution on the web. Worked for me.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is reenabled.
Here’s how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
This should work.
Posted on Jan 06, 2008
SOURCE: my TV will not work what now
I have just seen this problem - or simmilar. The TV I looked at never showed the DELL logo or any other video. The sound is good , and changes chennel... All seems to work fine, but no picture. Anyway, I have been a component level technician for 18 years. I have TV's sent in by local Casino for repair. I repaired this model and sent back this week. Will need to see how it holds up, but I upgraded the parts - so it should work fine and last longer. I am not sure that all the TV's in this model have the same boards in them. The other Dell TV's I have worked on have the same model numbers, but have different electronics inside. Anyway, this may be a problem that I can repair. You can contact me if interested at 1stchoice1@msn.com
Posted on Mar 07, 2008
Tv manual goodmans model ld2655hd so i can tune this tv
Try Googling (goodmans)(ld2655hd)(manual) without parens.
Jul 08, 2017 | Goodmans Televison & Video
Screen keeps changing colors and will not show picture
hi is it flashing red blue green, if so the tv is in screen burn mode, just press menu on the remote retune the tv, what is the model number of the tv you may need to go into the service menu turn screen burn mode off, thanks
shaun
Feb 25, 2017 | Televison & Video
Hi, I am getting "Activation Required"
##000000 should work to reprogram the phone, if it doesn't you will need to take it to your local sprint store for servicing.
when it does work it will bring you to a CDMA service screen, you enter your number (including country code) and then hit menu and save.
Apr 09, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Hi We have a envelope at the top right corner of our screen.. How do we get rid of it?
Your satellite or cable service has a message for you on your account. Depending on which service you have (DirecTV, Dish Network, etc.) the procedure will be slightly different. But a generic procedure is outlined below:
Using the remote provided by your television service provider, click on menu (might be system or something similar).
Once you are in the system menu, look for account services, messages or something similar to that (it maybe in a sub menu).
Look for messages, mail, or something similar and then read mail or inbox. Once you have read the message(s), the envelope will clear off of your TV.
Apr 04, 2011 | Televison & Video
Hi my plasma screen is only showing a faint picture and a million fuzzy dots can you help me
If this is happening on all input sources along with unable to see the menu. Best to get it into a good TV service shop as something has happened to one of the power supply boards. Call around for prices first.
Blessings always,
A/V Media Tech Guy
Nov 29, 2009 | Televison & Video
Dryer is heating but smells like something is burning. Clothes stink
HI,
i stronlgy suggest you that dont use it if you are smelling a un usual scent like burning wires.
to prevent any accidental that may occur.
bring your dryer or call a service technician to check parts by parts maybe some are only short circuited.
thanks,
May 28, 2009 | Dryers
Kodak EasyShare M853 lens/screen
Hey ginawill,
This is most likely due to a bad image sensor. If you are still under manufacturers warranty the repair should be covered, and if not I would have it looked at by an authorized service technician and get an estimate done. You can find an authorized service center by contacting the manufacturer, or you could bring it to a Geek Squad® precinct at a Best Buy™ store and they should be able to send it out for service.
Sincerely,
Allan
Go Ahead. Use Us.
May 19, 2008 | Kodak EasyShare M853 Digital Camera
OSD screen lock
The OSD is controlled by the video card board (logic board)
It is information stored on the eprom, not something you can just get to. It has to be programmed.
To gain access to the OSD Service Menu from a user service point you normally access it via a series of buttons on the control panel. Holding several buttons at once in a set combination that is particular to that brand, or even that individual series of monitor.
OSD just means "On Screen Display" the menu system and the service menu are the OSD.
Apr 21, 2008 | Computers & Internet
RCA P52921 Color/Alignment Grid
What your looking for is called the service menu. This is not an adjustment you should attempt unless you first read the service manual as the wrong button pressed while in this menu will cause permanent damage and an expensive repair. My best suggestion is for you to call in an authorized RCA repair person to do this for you, or purchase a service manual before you attempt this alignment procedure. Good Luck
Sep 28, 2007 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
