Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Television has a hard time coming on. power button comes on and off. takes forever for tv to come on
  • tomassfu2 Jul 18, 2010
    has it always been that way?.. i have a rear projection as well... but with mine i changed the bulb recently and it seems abit dull compare to a crt i have in the house
  • RCA Master
  • 8,617 Answers
Thats most likely caused by bad caps CP150, CP120 and CP114 on the deflection / Power board. You can get the cp150, CP120 and CP114 repair kit from www.tvrepairworld.com which contains the capacitors and the CD with repair instructions.
Posted on Jul 18, 2010
Panasonic plasma power button problem
Have you looked for bad filter caps on main power board?
Dec 09, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
I have a KP-FX53M91 Projection TV. When I switch it on with the remote, the light turns green but changes to blinking red. I have to repeat more than 15 times before the Tv comes on. Lalit Sodha
yes your problem is the high voltage power supply , on this problem you would has to hire a tech to fix this problem , the problem is a voltage control ic who turn on the high voltage if this is not working properly the tv never come on or sometimes take forever , normal repair cost is about 200-250
Aug 17, 2012 | Sony KP-53XBR200 53" Rear Projection...
RCA LCD TV red light flasiing tv won't come on
Bad main logic board. Probably won't be able to find it. You can try Encompas Parts. Good Luck to you.
Nov 20, 2011 | RCA L32WD22 32 in. LCD HDTV
The picture on the screen takes forever to come together
Could be logic board. It controls video out timing to panel.
Apr 14, 2010 | Samsung HP-T4254 42 in. Plasma Television
42 inch samsung lcd tv tv takes forever to come on clicks off and clicks on for about 20 minutes finally comes on then shuts off
I would check the power supply for bad caps they will have a swollen top replace those and that should fix your problem
Jan 28, 2010 | Samsung LN-T4665F 46 in. LCD Television
Tv takes forever to come on
tienes un problema de soldadura fria en el tv en general
Aug 28, 2009 | Televison & Video
TV takes forever to come on and then very dark
IM Afraid unit required to be serviced , problem at the inverter transformer or faulty capacitors at the POWER SUPPLY unit , hope this helps AJ
May 25, 2008 | Samsung SlimFit TX-S2783 TV
Problems with tv powering up
yea take your tv to a tech its having problem in the power supply or related circuits.good luck.
Apr 13, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
147 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
