Question about Creative Labs ZEN Vision:M Digital Media Player
Creative Zen V Plus
The Zen is looking for firmware, I have reinstalled all, rebooted, screamed and hollered, nothing works. It stays in the Recovery Mode.
Help.
    President:
  • 4,402 Answers
Booting straight to the Recovery menu
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
Posted on May 22, 2008
Listen to music and when into recovery mode
You will have to download new firmware onto your player. You can download it from here and if you scroll down, it will give you instructions on how to do it correctly: http://drivers.softpedia.com/get/FIRMWARE/Creative/Creative-ZEN-V-Plus-Firmware-1-32-01e.shtml
Aug 05, 2009 | Creative Labs ZEN V Plus MP3 Player
Zen v plus not recognized by media explorer
uninstall the driver and reinstall it by plugging the player back in.
Mar 28, 2009 | Creative Labs ZEN V Plus MP3 Player
Corrupt firmware
Reset the player by holding down the play/pause button and pressing the reset button with a paperclip at the same time. (the reset button looks like a little hole on the side.) This will put the player into recovery mode. Try rebooting the player. if this doesn't work, reinstall the firmware using that option in recovery mode. For more information go to the knowledge base at creative labs for your player.
Aug 14, 2008 | Creative Labs Zen Digital Media Player
When i turned my creative zen v plus mp3 on it said firmware problems.and i t had a choice to clean up delete firmware and reload firmware . 1 more it was reboot and i tried all of them and none of them...
my 8gb black white creative zen microphoto mp3 gets to the recovery mode screen and has the four options i tried every thing and it wont work wat do i do???????
May 20, 2008 | Audio Players & Recorders
Recovery Mode
I agree, use the Reload Firmware tool on recovery mode and then upgrade the firmware from the website. If you get "firmware failed!", then try it from a different computer.
May 08, 2008 | Creative Labs Zen Digital Media Player
My creative Zen
hello my Z has a white screen when i turn it on and it stays like that i can still hear my jams but cant see nothing or where iam going. what cant i do to fax it?
Zen Sleek not recognized by firmware: not connected msg
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
good luck
please mark the post with a fixya
Feb 19, 2008 | Creative Labs ZEN V Plus MP3 Player
My zEn...
you should not have had to install anything for the Zen to work on Vista. If you have installed any Creative software, remove it. Reboot, plug your player in, open Device Manager, and remove the device that shows up representing your player (completely uninstall it). Reboot again, and plug in your player. It should be recognized now.
If that still doesn't work, then boot your player into Recovery Mode, and perform both a Disk Cleanup and a Reformat. Reboot the player and try plugging it in again.
if it still doesn't try another computer and upload the latest firmware to it and then try it on your pc after firmware is loaded
http://us.creative.com/support/downloads/
try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
Jan 24, 2008 | Creative Labs ZEN V Plus MP3 Player
Recovery Screen, take 2.
If your Zen is not responding or in a "reboot loop" the following information from creative explains how to access the players recovery mode
Hope this helps, and good luck.
Zen V Plus and Zen V
1.
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
Dec 27, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
21 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
