Question about Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S
For a noritz N-06315 do I need an aux drain pan if it is installed above a living space
    Scholar:
  • 73 Answers
It depends on local code, no all cities/states require drain pans, but it is always a good idea if you don't want to deal with water damage.
Posted on Jul 30, 2010
Heater starts when cold hose bib is opened and there is no cross over in the hot and cold pipes noritz
You are describing normal operation. Does it NOT work any other time? If so, go to your remote and hold in the up and down arrows at the same time and hit up until you find number 14. this shows the flow rate. your flow rate has to be above 005 in order for the unit to start. try running a bathtub. if this starts it the problem is your faucets not allowing enough water through them. if this doesn't start it then you probably DO have a cross connection and you just haven't found it yet. Especially if the unit is running but the water never gets hot. Either way, call Noritz for them to walk you through it and you'll get it working.
Oct 03, 2013 | Noritz Water Heaters
Noritz Boiler NH-1501-DV-NG Shuts off at radom times with blinking error code 123
error code 123 is a flame rod sensor problem. Chances are the flame rod is sending a weak signal to the control unit. Check for a loose flame rod electrical connector. Peek in the flame inspection windows to ensure there is a proper flame on that side of the burner. If non of the above then try removing the flame rod and cleaning with 400 grit sandpaper or replace it with part order # SKC7448 (called an Ignition plug ELV & Packing EHK SETV)
Dec 16, 2012 | Noritz NH150-DV-NG Indoor Direct Vent...
Vibrating when the heater starts to heat water
Things to Check:
1. incoming gas pressure (minimum 5" when unit firing)
2. Make sure damper on top of unit isn't sticking
3. check vent length and #elbows versus installation manual specs
4. if above 2000', disconnect high elevation termination
If these all check out, you'll probably need to do a manifold adjustment. Call Noritz for assitance on this.
Apr 09, 2011 | NORITZ Natural Gas Tankless Water Heater...
The Noritz HW Heater has been tripping out some (usually whenever the shower is running, and someone turns on cold water). LED flashing three times. Any Ideas
This is probably a 16 error code. This code indicates the outlet water spiked above the set temperature for an extended period. It usually means the heater needs to be descaled or the manifold pressures need to be adjusted.
Mar 10, 2011 | Noritz 6.3 Gallon Residential Tankless...
Would you recommend this brand or another, with your experiences. We can get a used one noritz n-069m-od for $250...Go for it or not? We live on a well, 40-70 PSI, so maybe a bit low to work well?
The thing is with these that if they have been used in a "Hard Water" area, they get clogged up inside with deposits, so as long as it's a real "New" looking, inside and out, well I guess $225 - $250 would be an acceptable price. Find out WHY it is being sold.
Apr 17, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
Leaking Noritz water heater.... I have a Noritz N-069m water heater. When i purchased the unit 3 years ago, i was told that if i installed a water softner unit it would void the warranty. A year and a half...
Check your water pressure and the diagnostic codes on the controller to see if there is computer failure or another problem with the unit. send me an e mail i might be able to help im a nortiz certified service tech scott@bridgeplumbing.net
Jul 27, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
How to remove the water filter in Noritz
it's just a cup screen,, when you take off the cap screw you pull it out claen i and put it back,, it is on the cold side only right before the unit connection
Jun 22, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Water Heater Won't Fire up
I had the same problem with my Noritz 751M, I called the plumber and after he talked with Noritz and ran a bunch of tests (for $150) he told me I needed a new unit ($4,000 installed). They implied it was my fault cause I never flushed it over 8 years. They were unable to tell me the flow rate though (which should be very low if scale was my main issue). I decided to take over as I am very handy and an engineer. Here is what I found:
1. The unit is 8 years old and was never descaled (orig installer did not install the bypass valves nor tell me to flush annually). So, I installed the valves ($70) and bought a pump/hoses/bucket/Zep CLR ($150) and did the flush. There was tons of flow thru the exchanger (I did not measure how much).
2. I called Noritz myself (they were very helpful) and cleaned up the igniter rod with sandpaper (it was very discolored due to 8 years of sparking). This did the trick and my unit fired up but it was very sporadic (sometimes yes & no). The difficult part is that while the igniter is installed you CANNOT actually see (nor definitively hear) the sparking. It seems like sometimes the spark happens (unit fires right up) and sometimes it doesn't (unit cycles and ends in a Code 11 after a couple of minutes).
3. INFO: Per the field manual (Search google for: docslide.us_noritz-field-manual-2009) you can read the flow rate data from Data #14 on the remote control. It needs to be >0.5 GPM for the sparking to happen which then triggers the gas flow. You can live monitor Data #14 by following the instructions in the field manual on pp.46-47. The startup logic is: Flow > 0.5 GPM then Sparking Happens then the Gas Flows then Flames start in the combustion chamber
4. I got mine to successfully start by loosening the ignitor rod PN 101 and jiggling it while still inserted into the combustion chamber (holding it with insulated pliers while still against the case) - somewhat dangerous and startling when after sparking the gas flows and flaming starts but not too bad.
5. BOTTOMLINE: I got it working but it would not "always" light (even though my flow was always >0.5 GPM). Noritz told me that it is probably because I have the older black ignitor (PN 126 = EHEJ003). They have a new and improved gray ignitor (PN 126 = EMUJ004). I ordered it with a couple of other ignitor parts for a total of $35. I just installed them and they work great - ignition all the time from every faucet.
6. ENDGAME: Order the new ignitor parts, verify your flow rates using the field manual. See the pics below for some insight. I spent 20 hrs troubleshooting and wanted o share. If you want more info just email me at: tmorganjets@gmail.com
You can monitor the flow rate and flame by doing a skype (PC at faucet to Phone place in front of Noritz) - you will be able to see the Noritz turning on (with flow rate displayed) each time you turn on a faucet - it is very helpful for troubleshooting and verification
Feb 15, 2009 | Noritz 6.3 Gallon Residential Tankless...
Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
108 people viewed this question
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
