Question about Cuisinart CPT-60 Custom Control Total Touch 2-Slice Toaster
Cusinart toaster won't stay down
This is a Cuisinart two slice (long and wide) toaster for bagels. The White plastic model CPT -35. The toast lever will not stay down and therefore not operate. The lever itself is loose and come off. I am tring to take it apart and have removed the 4 screws at the bottom and the 2 screws holding the power cord retainer.
The corners at the bottom are very secure so maybe there are some screws under the rubber feet but before continuting, I was looking for a diagram on-line and have not found one. Can you direct me on the disassembly or the feasibility of repairing this toaster?
SOURCE: toaster won't stay in down position
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Posted on May 10, 2010
mc1bean
  • 3053 Answers
SOURCE: My compact 2 slice toaster
Hello, anton
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
SOURCE: when i push the lever down to make toast, it does not stay
no solution, problem, my lever (sometimes) will stay down, sometimes not, but it makes a loud "ractething" noise many times when the lever is pushed down>
best, randy
Posted on Dec 12, 2007
Alan ang
  • 24 Answers
SOURCE: Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Rdgs
alan
Posted on Feb 24, 2008
SOURCE: only toasts one side of toast
The cancel button is stuck in the in position
Posted on Jan 15, 2009
Hi my girlfriend just gave me this toaster, and would like to know what the lighted buttons are for thanks
Since you don't mention the make or model number of the toaster or its age I can only make the following guesses.
It might be an electronic model. To test if this is the case, leave the toaster unplugged and push the lever of the toaster down. If it does not stay down it is an electronic toaster. If it stays down then it is NOT electronic.
The lights might be lighted push buttons.
If you plug the toaster in then put a slice of bread or two in and push the lever handle down and one light comes on then this is probably a dual purpose pushbutton. It indicates that the heating elements are on and if you push it will cancel the toasting cycle and the bread slices should pop up.
If there is a button beside the above button it could be for extending the toaster cycle time a bit longer to compensate for a thicker slice or a denser bread like a bagel. If you push it, it will light up to let you know that the cycle has been extended for this reason.
If there is a button beside this one, it could be for extending the toasting cycle to compensate for a frozen slice of bread or whatever, like a bagel or even a frozen waffle.
If you find the make and model for your toaster, it might be on the bottom somewhere, google it to see if you can download an instruction manual for it.
Hope this helps. Good Luck.
Jun 03, 2017 | The Kitchen Appliances - Others
The thing you push down to activate toasting will not stay down
Check to insure the surge protector has not popped out. Reset and try again. Make sure its plugged in or it will not stay down.
Feb 01, 2016 | Cuisinart CPT-160 Metal Classic 2-Slice...
My Cuisinart Toaster's left side lights up
I repaired a problem with one of the sides of my CPT-180 toaster that was fixed by replacing C1. This may be the same component that Stan was referring to, as the C1 capacitor on the circuit board I was having problems with was bulging. I've attached some photos showing C1 bulged out compared to C1 on the good board.
C1 is the main power supply capacitor and if it goes bad, the circuit board power supply won't function correctly. This can lead to a broad spectrum of problems like the lever not staying down or the toasting control/timing circuits malfunctioning. If you replace the capacitor, it is best in most cases to replace with the same value as the orginal (220uf on my toaster)---you can usually get a replacement capacitor at Fry's Electronics. Replacing with a higher capacitance may be acceptable, but you should understand the impact to the rest of the circuit before you substitute a higher capacitance value. The voltage rating and temperature rating of the replacement capacitor should be the same or greater or the capacitor will fail quickly. Note the max temperature rating of capacitor C1 is +105C---toasters get hot (duh!) and the temperature around the circuit board of this model gets quite warm, so the temperature rating of the capacitor is critical. Finally, make sure the substitute capacitor fits when installed (requires soldering) and does not interfere with surrounding circuitry or other toaster mechanics when the circuit board is put back in place.
Pictures:
C1_location (next to screw)
Comparing_good_C1_with_bad_C1--note bulge on bottom of right C1
Right_orginal_C1_and_left_replacement_C1
Bad_C1 showing capacitance, voltage and max temperature ratings
5487aa4b-7e7d-4e6f-9542-cf9ff618008c.jpg2d853c87-48b6-4735-99f4-fdd5dbc60ffe.jpge1a82299-a243-46e1-b11b-4c20e0d9b304.jpg5543b7e5-8108-4b1d-bed3-90eee4600722.jpg
May 14, 2013 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster latch does not stay down on Cusinart CPT-120 compact two slice toaster
for Cuisinart cpt160: If the latch will not stay down it is because the electromagnet at the base of the toaster, which is supposed to activate when you push the handle down, is burnt out. I pulled my toaster apart and did a test of that mechanism and found that the solenoid was fried (open circuit). There are no replacement parts.
Jan 09, 2011 | Cuisinart CPT-160 Metal Classic 2-Slice...
When I depress the carriage control levers they do
my toaster did this once, i suggest that you get a new toaster from a different company, because if you've only had the toaster a month
and its doing this already that's a crappy toaster
Apr 20, 2010 | Cuisinart CPT-180 Metal Classic 4-Slice...
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
My cuisinart cpt 160 toaster won't start
Do any of the lights come on ?
If not then have you checked the plug top fuse
If the lights come on and then when you press the lever down it does not latch a solenoid has gone open circuit
Good toasters can be fixed
Cheap ones go in the trash bin
May 29, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Toaster arms will not stay down
Arms stay down by the mean of an electromagnet, controlled by a chip. If the wall outlet is functional, you should be able to turn on light by pressing the "defrost" or "bagel" button while the arm is held down. No light? the toaster is good for garbage!!
Mar 15, 2009 | Cuisinart CPT-180 Metal Classic 4-Slice...
When i push the lever down to make toast, it does not stay
This is a problem, our old toaster had this problem, and it would only work if we jammed the handle down, but don't try this, only because ours broke after we tried this, but if you can send it to the manufacturure, they should be able to fix this. If you don't what to do this, please phone me at 505 9181, but please call me from 8:00-10:00, 2:30-8:00.
Oct 21, 2007 | Cuisinart CPT-60 Custom Control Total...
4 slice toaster
open the unit. look for disconnected wires from sloppy factory
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Cuisinart CPT-60 Custom Control Total Touch 2-Slice Toaster Logo
347 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
