I have a wireless-g WRT54G ROUTER connected to a WMP54G wireless PCI adapter on my desktop. I'm not sure what I did, but the connection monitor shows that it is disabled and the screen shows "no association with access point". This monitor was working yesterday, how can I enable it again?? Thank you!! bj
    Problem Solver:
  • 21 Answers
Try unplugging and re -plugging it in.Then check to see if it is enabled,if not go to DEVICE Manager(Control panel)
right click on the item and enable it.
Posted on Apr 21, 2008
Just installed a Netgear Wireless-N 150 router and my other desktop - which has a Linksys Wireless-G PCI adapter (model WMP54G) continually toggels between Acquiring Network Address and Not Connected. Are...
if your useing a G network (the router is a G?) then the adapter will attempt to connect via N you have to tell the adapter to connect via G mode only, it cut the speed in half but it should work.
if you have an N router check to make sure the router will accept an N connection. via the network configuration page. depending on the router that may be at http://192.168.1.1 or http://192.168.1.255
Jun 10, 2010 | Linksys Wireless-G WMP54G 802.11g/b
Doesnt work on my msi
www.opendrivers.com/driver/.../linksys-wmp54g-v4-wireless-g-pci-adapter-driver-2.2.7.0-free-download.html
#3 question : network controller questionmark indicates it didnt find the driver it was looking for and shut it down.
Check this site for your driver
Apr 27, 2009 | Computers & Internet
No Active Internet Connection
If you want to use the wireless portion of your router, you would need a wireless adapter installed on your desktop. If you are getting internet on your desktop then this means that your wired connection is fine to the router is fine. The WMP54G adapter will work with your router, however if you are not planning on connecting to the internet wirelessly through the router then there is no need to purchase the adapter. Hope that this helps you out.
Serge C.
Mar 30, 2009 | Linksys Wireless-G WRT54G Router
I have a linksys PCI card WMP54G. Worked fine for 1 year now it will not connect. Other wireless computers still get stong signal from router. Checking control panel "wireless connection 7 Not connected,...
This is something to try:
Download drivers for your wireless device from this website. Afterward uninstall your wireless adapter. Then re-install it using the drivers you just downloaded. That should repair the issue(s), if not let me know and we'll take a look at other possibilities.
Mar 15, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Lost the Driver for Linksys PCI wireless adapter, model wmp 54g
Go to your Device Manager and on the right side look and find Network Adapters. Expand the Network Adapter by clicking on it so you can see your Wireless Network Adapter. If it has a yellow exclamation on it then you need to install the correct driver, if it doesn have that exclamation the it may already have the correct driver. It may also be disabled ( red X) so enable it.
Check the wireless connection properties.On the "General" tab and in the middle look for and find "Internet Protocol (TCP/IP)" . Highlight it and click "properties". Make sure here that if you have set-up your router to connection type of DHCP that "Obtain IP address automatically" and "Obtain DNS server address automatically" are the only ones checked.
Jan 25, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
We have one router hooked to our main computer in one room, we have a lap top that is functioning perfectly through this router. We are having problems adding an additonal desktop to this router? What...
hello!
if you will connect the desktop hardwired or dierctly to the router, make sure that the ethernet adapter is properly installed and the ethernet cable is working.
if you will connect the desktop wirelessly, make sure that the wireless adapter is properly installed on the desktop and make sure that the wireless settings are properly configured.
May 06, 2008 | Linksys Wireless-G WRT54G Router
I have an HP computer (Vista Home Premium Software) and Linksys wireless-G Broadband Router (WRT54G) installed and working. Problem--Trying to makea working wireless connection with a 2nd computer. An...
check that you have all updates for your linksys and cable modem and the new adapter you bought since your pc is old..
if that doesn't help then try the following:
i would shut down pc, uplug router power, turn off the cable modem and give it all at least 10-20 secs.. plug the other pc in the router then start up cable modem and router.. after that, then turn your pc on and see if it recognizes...
is the adapter for a desktop to make wireless of a laptop, just curious..
Feb 21, 2008 | Computers & Internet
Emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10005578
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail: http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=252286
As you will see there is a big differance between a NIC card & a wireless card.
Jan 01, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
