Question about Kodak EasyShare V530 Digital Camera
HOW DO I CHANGE THE SD CARD ?? - Kodak EasyShare V530 Digital Camera
    President:
  • 1,138 Answers
These are the physical specs of Kodak Easyshare V530
The bottom and the top of Kodak V530
On the right side of the Kodak v530, just look at the above image, you will see a slot in the center of the silver band covered with white felt curtain that protects it from dust. On this slot is where the SD card is inserted. Just insert the card carefully, and feel the click when SD card is placed properly, and push the card carefully until it bounced back and release from the slot when removing the SD card.
Posted on Jul 18, 2010
How do you move apps to an sd card? I have a plt2150
Hi Jackie.
found this on the internet hope it helps you out.
Move Apps to SD Card Using Application Manager
  1. Tap Apps.
  2. Select an app you want to move to the microSD card.
  3. Tap Storage.
  4. Tap Change if it's there. If you don't see the Change option, the app cannot be moved. ...
  5. Tap Move.
  6. Navigate to settings on your phone. ...
  7. Tap Storage.
  8. Select your SD card.
More items...
How to Move Android Apps to an SD Card - Tom's Guide
Jun 15, 2018 | Tablets & eReaders
I put an sd card into my tablet but my apps does not give me an option to save to sd card. What am i doing wrong. Not good at this stuff so help.
If it's an android, you can change it within an app - like camera. Go into settings and change default storage location from internal storage to sd card.
If the app can't see your sd card, make sure it's "mounted" within your device. Depending on the software version: Go to settings, general, phone/tablet management, storage, from here you should be able to see the sd card. It is either ejected or mounted. Click on the sd card, if you can see the folders content, then it is installed correctly.
Also, if it was used in another device, it may need to be formatted to be used in your tablet. You can do that from the same setting menu.
Hope this helps.
Jan 01, 2018 | Tablets & eReaders
How do I change storage settings from internal to sd card
The ZTE Zinger sets default memory storage automatically. If an SD card is inserted, then the SD card is the default storage. If not, the internal storage is used.You cant change the default storage location.
SD card ZTE Zinger
May 29, 2015 | ZTE Cell Phones
How do I change coolpix s52 to change from internal memory to sd card?
Try formatting the SD memory card using the camera's Menu setting.
May 04, 2012 | Nikon COOLPIX S52 Digital Camera
On model MFH-DGW2.1 it will not work with sd card. it will not recongnize card, i can not get it to change modes or get camera to work. take card out and camera works
SD card 101: the 2.1 MP cam is not compatible with newer sd cards...get standard SD class 4 or less; SDHD(high def);SDHC(high capacity);and classes above 4 may not work(class 4 SD cards usually have a 4 stamped just under the SD on card's label.
Aug 07, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I cant save files direct to sd memory all data is going to phone memory direct..how to activate sd memory as my default memory in E5 nokia mobile?
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings. Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
Jun 07, 2011 | Nokia E5 Cell Phone
How to remove the write protected micro sd card?
SD cards allow you to store digital information; you can use SD cards with most electronic devices like digital cameras and computers.
An SD card will become write protected if the switch on the card is placed on the "Lock" position. This prevents any information on the card from being altered or deleted.
If you wish to add, delete or change any of the information, you must remove the write protection.
Remove the SD card from the computer or digital device.
Locate a switch on the bottom or side of the SD card.
Move the switch to the "Unlocked" position to remove the write protection.
If you do not have a switch, you will need to remove the write protection with your computer.
Insert the SD card into your computer's card reader or back into the digital device.
You can now save and change information on the card.
Dec 06, 2010 | Kingston 1 GB microSD Card with USB 20...
I cannot access my SD card on my cellphone thus I donnot know where to open it on my menu
SD card in Nokia mobile can be opened in two ways,
1. Click on Menu --- > Gallery ---- > SD Card
2. Click on Menu --- > Applications --- > SD Card
By default the name of the SD card is "no name". You can change that name as the following
1. Menu --- > Applications --- > SD Card --- > Options ---> Rename mem.card
Enter the new name and press ok.
Jun 26, 2010 | Lands Phones
I like to up grade my sd card on my magelian 360 roadmate E-mail as follow:bojo9335@verizon.net
To change the sd-card do the following:
Peel back the rubber gasket to expose the SD card slot. Do not
completely remove the rubber gasket.
Push the SD card until you hear a click. Do not attempt to pull
the card out of the slot
Remove the SD card from the slot.
To Insert new SD Card
Insert the SD card into the slot (Do not force
the card into the slot.)
with the metal contacts going in
first and the beveled edge to the left.
Close the rubber gasket.
Mar 22, 2009 | Magellan GPS
Kodak EasyShare V530 Digital Camera Logo
93 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
