Question about Kenwood KDC-MP342U Car CD Player
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and enter the code.. it goes right back to protect mode... is there a way to ''hard reboot'' the thing?
    New Friend:
  • 4 Answers
Hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
Posted on Jul 24, 2010
SOURCE:
Trying to find a wiring diagram to install my kenwood kdc-mp342u into my 2001 grand am. any ideas?
Please let me know if you have any questions, and thanks for using FixYa.
2001 Pontiac Grand Am Car Audio Wiring Diagram kenwood kdc-mp342u
Car Radio Battery Constant 12v+ Wire: Orange yellow
Car Radio Accessory Switched 12v+ Wire: none
Run a wire to the fusebox for switched power. red
a 14 gauge wire will do--use a 15 amp fuse
Car Radio Ground Wire: Black/White black
Car Radio Illumination Wire: Gray (tape this wire off) none
Car Stereo Dimmer Wire: Brown (tape this wire off) none
Car Stereo Amp Trigger Wire: Pink blue
Left Front Speaker Positive Wire (+): Tan white
Left Front Speaker Negative Wire (-): Gray white/black
Right Front Speaker Positive Wire (+): Light Green gray
Right Front Speaker Negative Wire (-): Dark Green gray/black
Left Rear Speaker Positive Wire (+): Brown green
Left Rear Speaker Negative Wire (-): Yellow green/black
Right Rear Speaker Positive Wire (+): Dark Blue purple
Right Rear Speaker Negative Wire (-): Light Blue purple/black
Amplifier Mounted behind trim in the left side of the trunk.
May 19, 2011 | Kenwood Car Audio & Video
My unit says protect on it and i can't find my paperwork with the code. Can you help me?
Usually the "protect" light indicates you have a shorted speaker or speaker wire. Most speakers have a rating of 4-8 Ohms. If it is lower than 4 the unit will go into a protect mode to keep the internal amp from being destroyed. Make sure none of your speaker wires are touching metal or each other. A blown speaker could cause this to happen also.
Apr 07, 2011 | Kenwood KDC-MP342U Car CD Player
The word "protect" is blinking and none of the
PROTECT (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
Mar 26, 2011 | Kenwood KDC-MP342U Car CD Player
My radio is in protect mode. How do i get it off?
If it is in protect (Blink):- The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated. Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
Mar 20, 2011 | Kenwood KDC-MP342U Car CD Player
I have a kenwood it says,kdc-mp142 and all of a sudden it just says protect. it wont do anything
The Kenwood radio will generally give a "PROTECT" error if the amp or receiver is being overloaded. This may mean that some of your wiring may have gotten frayed, one of your speakers isn't putting out the right voltage, or the receiver has decided to go bad. Make sure all of your connections in the back of the radio are solid and not frayed. If that's not the problem, try running each of the speakers one at a time. If one causes the radio to go into protect mode, that's your culprit.
If neither of these are the issue and the radio decides to stay in "protect" mode, your receiver may have seen better days and may need a replacement.
Feb 28, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
Kenwood KDC-MP732 CD Player in protect mode how do i get it off had a blown speaker fixed it and still in protect mode
Protect Mode (Blink): The speaker wire has a short-circuit or touches the chassis of the vehicle, and then the protection function is activated.
Solution: Wire or insulate the speaker cable properly and press the reset button.
Here is a copy of the Instruction Manual for the Kenwood KDC-X790 and KDC-MP732.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 25, 2010 | Kenwood KDC-MP732 CD Player
How can i deactivate the protect that blinks in my kenwood car stereo, the stereo i have is the kenwood kdc mp342u model
Disconnecting the terminal will take to much time.. In between the skip button ,and the #1 on your stereo there is a little dot. Barely noticable unless you know what your looking for, take a safety pin or a screw( anything with a little tip) and push it in. This will restart your stereo. (Car Must be on)
Feb 11, 2010 | Kenwood KDC-MP342U Car CD Player
The screen on my KDC-MP342U just blinks with the word PROTECT
first, check your speakers and speaker wires for shorts, then disconnect power to the radio for a few seconds and reconnect it. if that doesn't work, then you probably have a bad output ic.
Dec 03, 2009 | Kenwood KDC-MP342U Car CD Player
All it says is protect and nothing works what do i do
the protect message flashes on my KDC MP342U radio. I have unhooked each speakers one at a time and reset the radio but the protect still flashes
Nov 19, 2009 | Kenwood KDC-MP342U Car CD Player
Kenwood KDC-MP342U Car CD Player Logo
3,407 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
