Question about Samsung Weather Resistant Security Camera SSC-12C
I have a ssc-12m monitor that seems to power cycle when the power sw. on the back is turned on. I can hear the flyback cycling and a clicking. Initialy the sys. worked for a week. (the ssc-12m is brand new, but set on the shelf for 5 years. Any suggestions?
  • 1,906 Answers
Remove power; remove the cover with a multimeter on "ohms" check the fuses look over the circuit board for burned components, leaking "domed" leaking capacitors next using component coolant from radioshack cool the i.c.'s as you turn on and, off the monitor.
Posted on Jul 18, 2010
Complete service manual for Samsung B/W Observation Monitor SSC-12M AC120V, 60 Hz, 38 W. The green front panel power lamp flashes and the machine emits a clicking sound. I have checked connectivity to...
Unfortunately, the devices aren't listed as the "set" - can you reply with the exact model number from the main unit?
If i cannot obtain the schematics after hearing from you... I will contact Customer Service to initiate a refund or switch to another expert.
Thanks!
Sep 28, 2011 | Samsung Weather Resistant Security Camera...
Looking to buy a moniter
I have two monitors.
I don't use them, because I used and adapted the cameras in another cctv system.
You can see a picture of them here
http://www.palleyd.com/ssc-12m-monitor.html
Jan 19, 2009 | Samsung Weather Resistant Security Camera...
Whirlpool Dryer GEQ9800LW0 won't turn on
Hi!!! it seems that you have a bad thermal fuze located near the blower..change the thermal fuze and you should be okay..Good luck..
Jan 04, 2009 | Whirlpool GEW9200L Electric Dryer
Seem unable to get my ink cartridge holder in middle position to insert new cartridge. have tried 2 TR27 copy cartridges from ABITECH Nottingham but both made the error light flash ! Printer id EPSON...
I cannot remember if the Status Monitor (SM) of the 810 has a "change cartridge" facility, but it's easy to check. Right click the printer icon in the bottom right-hand corner of the screen and select printer settings. Then click the maintenance tab - is "change cartridge" one of the options? If so, use it. If it isn't you can download the SSC utility from
http://www.ssclg.com/epsone.shtml
and use this to move the cartridge to the cartridge change position - don't forget to use it to do an ink charge cycle after you have replaced the cartridge.
There is also the "generic" approach. Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move (gently!) by hand to the cartridge change position. The snag here is there is no inherent means of running an ink charge cycle - do a couple of head clean cycles instead.
Sep 15, 2008 | Epson Stylus Color 460 InkJet Printer
I have a Samsung B/W Monitor, model Name SSC-12M for an observation System. Turns on for a few secomds, and then gets a straight line across and turns monitor on and off, Capasitor maybe? Worth repair ing...
The vertical Ic either has bad connections or is defective. Look for a small flat IC attached to a heat sink with about 11 pins. Try resoldering the pins first. If that fails to resolve it, replace the IC. This IC may be marked LA7837 or something similar. If you are unsure, post the marking here and I'll confirm you have the correct part.
Dan
Aug 28, 2008 | Samsung Televison & Video
No picture
The green connectors are for PIR (passive infrared ) motion sensors to be connected, they have nothing to do with you recieving a signal from your cameras. Double check to make sure the camera jacks are securely connected on both ends (camera & monitor) , and then hit your AUTO button which should automatically cycle through your cameras if you are indeed getting a signal. If you arent, you have other issues. As to the monitor getting darker. You will need to adjust the brightness from day to night unless you have an alternate light source or IR(infrared) Illuminator for night viewing.
Feb 20, 2008 | Samsung Weather Resistant Security Camera...
Samsung B/W Observation System - Model# SSC-12
I have the same problem and I found out that a resistor went bad and then a capicator went bad.you must have them check and replcaced
Oct 26, 2007 | Samsung Weather Resistant Security Camera...
Looking for a manual for A Samsung SSC security system
Am not familiar with an SSC-960, there are however SVR-960 (4 versions) by Samsung.
Normally Samsung follows similar installation procedures and the differences in their model are advance features and the length of recording time. If this could be of any help, this link is a users’ manual for a 1280 hrs model. It includes installation procedures.
Alternately you can try Google for “svr 960 pdf” but when I tried it most that I can get are German language versions.
Hope this be of some help/idea.  Good luck and kind regards.
Aug 25, 2007 | Samsung Weather Resistant Security Camera...
*HELP* No Picture, Turns on, No Pic whatsoever.
you didnt mention if your audio is o.k. if has no video and audio the problem is in the flyback? yoke? HV section. i need to check it personaly. post more forum so i can determine the problem.
Dec 29, 2006 | Samsung TXN2771HF 27" TV
Samsung Weather Resistant Security Camera SSC-12C Logo
106 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
