Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
I have a brand new dishwasher that i recently installed, water is not being drained out of the bottom of the dishwasher. i'm thinking it is not draining at all, suds keep leaking out the door, dishes are dirtier after they are washed, the garbage disposal was already being used on my old washer so there is no plug on it, i can find no kinks in the drain line. what and where should i look to find and remedy problem?
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasheri have a brand new dishwasher that i recently - 2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 18, 2010
How to fix samsung dishwasher code se
The code is 5E
If your dishwasher is displaying error code 5E, It can be caused by a kinked drain hose.
If the drain hose is kinked, there will be an excessive amount of water in the bottom of your dishwasher after a cycle has been completed.
In order to access the drain hose you need access to the back of the dishwasher. If your dishwasher was recently installed, contact the installer to move the dishwasher and inspect the drain hose.
If the drain hose is not kinked, but your dishwasher is still not draining, service is required.
Apr 21, 2015 | Samsung Dishwashers
Water does not completely drain from bottom of dishwasher when cycle has completed.
May just need to take sump apart and clean or you need new drain pump
Mar 23, 2015 | General Electric Dishwashers
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
I have a brand new whirlpool DU1055XTV5 dishwasher, installed two days ago. After the cycle completes there is about 1/2" clean standing water left in the bottom. It is not just down in the well area,...
Ensure the outlet pipe is below the level of your floor and straight to a drain or plumbed into the waste pipe directly with no chance of syphoning from standing water in your drain/waste pipe.
Apr 04, 2017 | Whirlpool DU1055XTS Built-in Dishwasher
HI i have an electrolux dishlex dishwsher that is brand new and just installed. Ive used it a few times an dhave noticed that there is water at the bottom of the dishwasher, thats not draining, I thin
there is always a little water in all dishwashers. Sounds like to me that you may have a kinked drain hose or maybe the way you have hooked the drain up. The drain hose should go to a vacuum break that is mounted on the sink flange and then another hose goes to the disposal. If you have the hose hooked directly to the disposal you may be getting water back from the sink to the dw. raise the hose up as high as possible and attach under the sink so there is a high loop in your hose so water cannot drain back from the sink
May 29, 2009 | Dishwashers
Water in bottom of dishwasher after cycle
as ur dishwascher is brand new why not call the service and get the, solve the problem.....or u can go in touch with the store u bought the dishwasher and ask them to fix it....i think it will be under warranty being new
Mar 14, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
Whirlpool DU 1050
Hi, I bought a brand new Whirlpool Gold GU2275XTVS that had the same problem after I installed it (standing water in the bottom after the cycle--although it would drain out if I pressed the drain/cancel button...not sure if that applies to you). It's less than a month old and still under warranty, so we had a technician come look at it but he couldn't figure it out. I've been searching these appliance repair forums for answers but found none that applied to my specific problem. I'll share what I found in a second, but first here are the most common problems associated with slow/not draining: 1) your air gap (if you have one) is clogged, 2) your drain hose is kinked or clogged, 3) your garbage disposal drain plug was never removed or the disposal drain is clogged, 4) your pump is damaged or doesn't run at all. There are a lot of appliance forum Q&As that address these issues. If you checked each of the above problems and still have the problem--especially if you have a brand new dishwasher and clogs should not be an issue--then read on...
I unhooked my drain hose and tried the simple "blow test" (just blow into the hose to see how difficult it is to force any water into your drain/disposal). If there is a lot of water in the hose it will be difficult at first, but after blowing water out it will get progressively easier. I discovered that it wasn't necessarily difficult to blow air through the hose, although oddly it got MORE difficult the harder I tried to blow air through. I then realized that the check valve (keeps drain water from returning to the dishwasher) was inside my drain hose instead of attached to the pump. If you have the same Whirlpool drain hose, the check valve is just past the first elbow of the drain hose where it attaches to the pump. I couldn't see it, but when I stuck my finger around the bend I could feel the valve. What's more, the valve flap was toward me--which means that it was (at least partially) closing off as water tried to drain out of the dishwasher instead of closing off any backflow. It came from the factory like this; luckily it was an easy fix. I simply pushed the valve flap through to the other side of the valve hole. Problem solved--it drains like a champ.
Hope this helps.
Feb 27, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Dishwasher not draining
if its new call your dealer its a warranty call
Dec 22, 2007 | Dishwashers
Drain
Don't buy this brand anymore, and be sure all your friends know not to also. I have a GE, GSD4000J, it is less than 2 years old, I have used it maybe at most 6 times. Now it will not drain, washes with the same water, does a terrible job of washing. I own a remodeling service, I will never buy GE products for any of my jobs from this day forward. Have not been able to get any help from GE, they don't seem to stand behind their products at all, or care about their customers once you have bought their products.
Oct 30, 2007 | Dishwashers
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
74 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
