Question about Garden
Bolt broke off when trying to take blade offhow do i get the broken pice out
  • 51 Answers
If it is broken flush you must drill out center of bolt and use ez out or bolt extractor. may want to soak with penetrant or heat bolt before using extractor,if it wont come out you will have to drill out to size of bolt and re thread ,last option replace spindle . hope this helps
Posted on Jul 18, 2010
Sorry the mower is Poulan pro 625 ex the bolt broke that holds the the blade on need to buy new one what size or type do I need . Please and thank you
If the bolt broke, you need to remove the threaded part of the bolt that is still in the shaft... once you get the broken part of the bolt, out.....it (the threaded part) will tell you what size/thread pitch you need... just take it with you to the mower store or a industrial supply store..
Fastenal Industrial Supplies OEM Fasteners Safety Products More
Grainger Industrial Supply MRO Products Equipment Tools
Jul 14, 2017 | Poulan Garden
Bolt broke off of adapter and blade. I replaced bolt and it broke again. So i replaced the bolt and adapter and now making a loud knocking sound this is on my cub cadet walk behind sc500z
Hi Diana:
I'd suggest that you pull the spark plug lead so it does not accidently start, and then try this.
Place the mower at a height where you can easily see under it. I use the tailgate of my pickup trucl.
If you put the handle inside the bed of the truck you can put a weight on the handle so the deck is tipped up. With the spark plug disconnected (or even removed) rotate the blade. Chances are that the knocking sound will be from the blade hitting the deck. It is possible that the bolts keep breaking because the blade is not seating properly.
I'm guessing that once you can see under the mower you will find the problem.
Aug 11, 2016 | Cub Cadet Garden
Pro tech miter saw model No. 7208
Drill broken bolt and use an easy out to screw broken bolt out. It is left hand thread.
Mar 01, 2014 | Saws
Do you have parts for a Fiskars 31 in. Titanium Bypass PowerCurve Lopper
send a photo of any broken fiskars tool or product to their email address and they will send a replacement to you free of charge... ni buy fiskars because they have lifetime warranty!
Dec 28, 2013 | Cars & Trucks
I hava a 7 1/4 circular saw model # 5250. The blade broke off and we can't get the bolt loosened enough to replace the blade. Any ideas on how to get bolt off?
If you have no way to prevent the motor from turning when you try to remove the blade bolt, you are going to have to immobilize the armature to get it off. Remove the cap on the motor housing so you can remove or relieve the spring pressure on the brushes. Then remove the motor housing with the field, leaving the armature attached to the blade guard/transmission assembly. Now you can safely hold the armature while turning the blade bolt.
Oct 06, 2012 | Skil 5250 Circular Saws
I have a cutting deck blade nut half off and cannot get it all the way off or tighten it back up. I have had the blades off to sharpen before. Is there a special tool thai I need to know of? Thanl You, ...
If as you say this is a nut, most likely what happened is the threads broke inside and created a foot in the door problem. You would need to cut off the nut and replace with a new nut, or replace the bolt . If the problem is with a bolt with broken threads, it's the opposite, but you may have to drill out the bolt and retap the bolt hole. GOOD LUCK.
Aug 24, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
Broke off the head of the bolt that holds the blade on a 6 1/2 inch cordless 18v circular saw. How do I get the broken stud out?
If the threads are not bound, you might be able to use a sharp pick to work the broken part out. Otherwise, you will have to drill out the center of the bolt with a small drill bit and use an 'easyout tool' that will fit tightly into the drilled hole which will allow the piece to be backed out. Good luck!
Apr 15, 2010 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
MY YIBOO CHINOOK HAS A BROKEN MAIN BLADE HUB. WHERE CAN I FIND REPLACEMENT FOR MAIN BLADE AND SHAFT?
I found this on xheli.com. Syma S022 big CH-47 chinook.
Looks like the same heli as Yiboo. Lists all spare parts.
Good Luck. Please post results if you order from this site.
I also have the Yiboo CH-47, have not needed parts yet, just got it for xmas from my wife.
Sep 15, 2009 | RC Toys
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
