Back to:
Tags:
Washing Machines
Generic problem for all Washing Machines
Hot water runs in real
posted by cinnyarg on Apr 21, 2008
hot water runs in real slow
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 21, 2008
Not Rated (0)
fixum1
Rank:Guru Guru
Rating: 88%, 483 votes
check and if dirty replace the screen in the water inlet valve or in the fill hose if the hose has a screen in it
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on hot water runs in real:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
Washing Machines
i have a bosch washer dryer wvti 2840, have put some...
Washing Machines
the washer cycle beep signal is very much lower/softer...
Washing Machines
Maytag wringer washer. Pad you stand on to make the...
Whirlpool Duet 3.8 cu. ft. Capacity Front...
Every time you put your clothes in the washer, pull your...
Whirlpool Duet GHW9150P Front Load Washer
All other functions, including agitate and drain, are...
Loading problems.
Repair Service
Find Washing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
