Question about Whirlpool GB2SHDXP Bottom Freezer Refrigerator
The back part of my freezer keeps icing up.
The back part of the freezer is icing up and the ref is not staying cool. After I deice the back part of the freezer the ref returns to cooling. How do I keep the back part of the freezer from building up w/ice. This has happened three times in the last month.
  • joeschuvart Jul 22, 2010
    not sure. You indicated the defrost mechanism is located in the upper right side of the refrigerator section, however there is no access to the refrigerator section. There is access to the freezer section. Is the defrost mechanism located in the freezer section or the refrigerator section?
    Guru:
  • 528 Answers
Hi. Sounds like you have a faulty defrost timer, or adaptive defrost control board. The defrost mechanism will vary form unit to unit. Most newer units will be equipped with a defrost control board. This will be located in the control housing, just above the heat shield, in the upper right had side(refrigerator section). Older models will have a standard defrost timer mechanism. If this device fails, the evaporator heater Assembly will not receive the command to defrost the coil, on time(This will block airflow and jam the evaporator fan blades). The easiest way to isolate the cause, will be to test the heater element. If the element is functional, the defrost timer/board, will be the culprit.
Posted on Jul 18, 2010
  • joeschuvart Jul 18, 2010
    Is changing out the defrost time a project that needs any special tools?
  • Archie Cruz
    Archie Cruz Jul 18, 2010
    Hi. You dont need special tools for that. All defrost timer is pretty much standard. Here's another link on how to test and replace defrost timer. Please click here.
Magic chef RB150R freezer won't cool, refrigerator sorta cools. Freezer fan runs all the time
In the back there is a radiator and it is frozen solid, you have to deice it, unplug the fridge and take the cover off and remove the ice build up, hair dryer should do the trick, or leave it unplugged for few hours.
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Jan 13, 2018 | Magic Chef Refrigerators
Freezer stays cool but won't freeze
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 06, 2011 | Kenmore Bottom Freezer French Door...
The tempature on outside of refrigerator is blinking and the frig side isn't staying cool
I'm Leo
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Also check evaporator fan in freezer
If this was helpful please rate me
Leo Ponder
imufo2
Jul 24, 2011 | Samsung RS2578BB Side by Side Refrigerator
We keep having to "defrost" our refrigerator. It is five years old. A repairman came out and showed us how to take the inside back panel off of the refrigerator part and de-ice it. Why does ice keep...
A lack of refrigerant or a compressor problem might be the cause of freezer low efficiency but that is unlikely to blame for the buildup of ice in the refrigerator.
A certain amount of ice is normal and initially in the evolution of the fridge there was a need for routine deicing, typically just a few times each year. Later a heating element was included to ease the task of defrosting.
These days the heating element is now automatically switched on briefly every time the cooling cycle finishes and the resulting water drained into a cup mounted on the compressor. The heat from the compressor evaporates the water and the fridge remains frost-free.
I expect your fridge should be frost free and clearly the auto defrost is not working. This shouldn't be a great problem and if everything else was good it would just mean routine deicing like the early days. Clearly everything else is not good and the buildup of ice is much more than normal.
Assuming it isn't caused by an elementary mistake like placing hot food in the cabinet there are two main causes of excessive ice buildup - one is a defective door seal and the other is failing cabinet insulation, the latter marked by the compressor needing to run longer to maintain a low temperature and parts of the outside of the cabinet feeling "chilly".
Oct 05, 2017 | Samsung 26.1 Cu. Ft. Side-by-Side...
RFA52 upright fridge freezer keeps frosting up.what is the 'normal' setting for the freezer 0 or 1?
Setting should be midrange. If the freezer is frosting on the back panel you have a defrost problem. The coils will be iced over and the unit will slow down on it's cooling. If there is frost you will need to deice the coils by removing the frezzer back wall panel and use a hair dryer to melt all of the ice. The problem causer of all this will be either the defrost timer, defrost t-stat or defrost heater. Good luck.
Feb 28, 2010 | Freezers
Coils inside freezer keep icing up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model of fridge)
Aug 08, 2009 | Refrigerators
I have an admiral model HMG 67184 side by side and I can't figure out why my freezer section still works but doesn't get cold enough to make ice cubes and the other side doesn't work at all. I do have...
1. Get the Food out of the Ref and Freezer. Unplug the power cord from the wall.
2. The cooling coil is in the back wall of the freezer side. Working from inside the Freezer.
3. Remove the back plastic cover to expose the cooling coil. It's called the Evaporator coil.
4. Use a hair dryer to melt all ice off the coil.
5. Put it back together. It should work for 3 - 5 days now at least.
6. Put a thermometer in there. After 24 hrs. the freezer should be 0 to 10 degrees F. and the Ref. side 37 to 44 degree F.
7. Check the door gaskets for tight fit, using a dollar bill for a gauge.
Shut the door on the dollar and try to pull it out in several places.
If it ices up again in a week or two, you have a defrost heater problem. There is a electric heat strip around the cooling coil. This heat strip comes on about 10 minutes every 8 or 10 hours. This heater melts the ice off the coil. There is a clock timer device under the ref. that cycles the heat strip. You may have a bad clock, fuse device or burned out defrost heater strip. The cooling coil must be ice free to work properly.
Jul 06, 2009 | Admiral 26 cu. ft. Side-By-Side...
Fridge part is not cooling; freezer is frosting up
your ref. has a defrost problem.you will need to take back panel off inside freezer and take your hair dryer again and defrost the system.then you can check your heater,thermostat which is located at top of coils that were defrosted.sometimes the thermostat will pop and not allow it to go into defrost and you need to check defrost timer.
Mar 12, 2009 | Refrigerators
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator/freezer not staying cool
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
If there is no frost on the freezer side it may be low on coolant.
Dec 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool GB2SHDXP Bottom Freezer Refrigerator Logo
55 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
