My wharfedale LCD37F1080P has no pic or sound standby light flashing but wont let me switch on, iv tried disconnecting power and restarting but nothing seems to work
  • taz10000 Nov 28, 2008
    same here, but mine comes on after 20 minutes
talknerdy2me
SOURCE: samsung hc-r5245w no power
Hello Chac c,
The reason that you are getting a 'red light' is because your lamp is burned out. There is a panel on the back of the TV that gives you access to this lamp. You can remove it and check the part# to be sure then replace it. I did a quick search for you just based on the model# which you provided. You can see it here - http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=samsung+lamp&gg_site=&gg_aid=1295966762
Hope this helps :)
Posted on Mar 17, 2008
SOURCE: STANDBY LIGHT IS FLASHING
The standby light blinks 5 times
Posted on Mar 30, 2008
ladywinn
  • 5138 Answers
SOURCE: KP-57WS500 8 blinks will not power on
High Voltage Splitter Block #8-598-955-32 8 Blinks Call MAT electronics 1-800-628-1118 or Electronix Parts 1-800-223-3205 or you can go to thier websites online.
Posted on Jan 04, 2009
  • 11 Answers
SOURCE: dead tv :-(
replace all caps in the psu.
Posted on Mar 19, 2009
Slinteriors
  • 8617 Answers
SOURCE: sony kp-51ws510 tv blinking light 6 flashes on timer/standby
6 blinks on your model means the +5V line is either overloaded or shorted on the A or B board. You can get replacement boards at the following link and they will assist you in determining which board of the two you actually may need.
http://servicemanuals.vstore.ca/
Posted on Mar 26, 2009
Wharfedale 42 LCD37f1080p has picture distortion please help
Just a quick thing to check there are no speaker / surround sound speakers ( magnets ) near tv as this can affect screen
Apr 06, 2014 | Televison & Video
Tv wont come out standby
That is irritating to have a tv that is neither off nor on. I presume that you have restarted it. If not do, disconnect the tv and the router and other appliances that may be connected to the tv. Disconnect for two to three minutes, connect to electricity again and make sure that all cables are where they should be. Hope you get this sortedvout, kolbrun
Sep 18, 2013 | Sansui Televison & Video
Wharfedale dvdr24hd169f stays in standby no displays wont accept commands
The problem is in the power supply board, often caused by a defective capacitor that becomes open, cap value is usually around 1000uf and sometimes shows a bulge at top leaking contents, if you are handy with a soldering iron replace part with identical value and voltage rating and observe the polarity.
Jun 09, 2012 | Wharfedale Televison & Video
Wharfedale 32" L32TA6A
many questions like this and only answer is to dump it and buy a new one as these modern LCD TVs are repairable as such and you can only change a board and the wait to get one and the cost ? you may as well buy a new TV
Dec 11, 2011 | Wharfedale Televison & Video
Standby light flashing but no pic no sound on
Power Supplpy board is dead.Replaced the power supply board will solved the power flashing.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 22, 2010 | Televison & Video
It keeps flashing between flashing lights regards
Hi.
The TV stays in standby because protection circuit kicked in.
Protection kicks in when an internal fault had been detected.
In your case the SCART cable may have caused a short.
When on protection the TV will stay in standby, will not respond to buttons or remote, and will not start up.
All higher voltages from PSU get shut down by controller board, and only the +5V remains on.
To attempt resetting the TV, disconnect all video cables, disconnect the power cord, wait about one hour and plug it back.
If TV does not restart, then there may be an internal fault.
In that case leave TV unplugged for longer, just in case.
If still no luck, then call Sony to discuss a repair. The number is listed on your owner manual.
If instead TV will restart, do not use the faulty video cable again, this can damage your TV.
Regards
Nov 06, 2009 | Sony Televison & Video
Kdf-60xbr950 no pic or sound. standby light flashing
Sounds like the lamp is bad. Might be time to replace the TV.
Mar 31, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Trying to connect my pc to a wharfedale lcd37f1080p using the standard moniter cable and am getting the message !out of range! on the tv
Change you screen resolution to lower resolutions, like 640x480, connect it. if you get video, move your resolution up and test which ones work for you TV. Try to stay under 1920×1080.
Dec 07, 2008 | Computers & Internet
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
Sony kv32fs16 problem
The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Nov 02, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
