Try taking the battery out and if doesn't work have to go and see Blackberry dealer or where You got your Blackberry. These are software problems which I have also faced.
As I understand how things work, you should be able to get you key fromyour service provider, ifnot then the company that sold you your Blackberry. Give this a try. Kolla
Try this, Place some cloth, or a glove on your finger and see if the track pad detects your finger.
If it does response then the problem is with the track pad sensibility. If it does You will have to adjust the sensibility and/or clean the track pad from any dirt.
If that doesn't solve your problem, you have a damaged track pad that needs to be replaced.
Let me know if you need further assistance on disassembling the curve and replacing the track pad or with any other question you have.
Try to insert any password in your phone 10 times to erase all your data and make your blackberry Tour 9630 unlocked. If your keypad still won't work after blackberry unlocking process, try to reflash your blackberry phone. Once again if still have same result, it should be a hardware problem in your phone and you need to repair that on nearest local mobile phone repair shop.
Just check for the key combination on your key board (ex. Fn + F4 or F5..depends on the what key was designed for the touchpad), the touchpad might be locked.
If it is not locked, reinstall the touchpad driver, but it this still doesn't work, boot to Safe Mode to check if it does. Touch pad still not responding in Safe Mode would mean hardware failure.
you have a stuck key you need to find which one and you need to blow the key pad off with compressed air to disloge the object that is sticking the key.
