Question about Kenmore Washing Machines
Need to get Agitator off!
I have a kenmore 80 series mode # 110.20802.990. I am trying to replace te drive block assembly and cannot figure out how to get the agitator off. Ive remove the fabric softner cap... but there is still no immediate opening for access. only seam is halfway down the middle. What am i doing wrong.
  • detroit_riot Jul 18, 2010
    by the way its says dual action...double roll over on top of it.
    That was it! Thanks... Tried getting spanner nut off without buying $30.00 wrench. Gonna try the pipe wrench instead seems really tight..will keep note on block of wood!
    President:
  • 1,937 Answers
First, see the Sears parts diagrams for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20802990&pathTaken=partSearch
Look at the section on the agitator, basket and tub for a good description of how everything connects.
Also see the following, it has a good section on removing the agitator:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Most likely, you didn't pop off the agitator cap. Under it is a 1/2" plastic bolt. Once the bolt is removed, you should be able to pull the agitators off and see the drive block.
NOTE:
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
Also see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Jul 18, 2010
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
My kemore 80 series washer wont spin
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} We had the same (plus another) problem with an old Kenmore top load, direct drive,neutral drain washer.
Problem 1. Major gear sounding grinding during spin mode. Major vibration also.
Problem 2. Spin problem. Most times the washer would drain but wouldn't spin unless the lid was raised and lowered. (According to wife, this problem has been on-going for two years).
After checking motor coupling (a bit worn but intact), drive block (you don't need a spanner wrench to remove it, a 12 - 14 inch pipe wrench works great) which was OK, clutch, seemed OK, we determined that the problems were in the transmission.
Two options, 1 spend $150 plus for a transmission.
2. Open it up and see if anything seemed seriously bad.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
the first problem seemed to be related to the agitator cam and cam follower not raising the agitator gear high enough (probably less than a 1/16th of an inch) above the agitator cam.
Found the right part number (Whirlpool part # 62580 / 81) which includes both the cam and follower. Bought one for about $10.50, installed it, put washer back together and problem 1 was solved.
Looked again at parts list and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
Those cams/gears etc. keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
Put the washer back together and I now have a happy wife. Everything works as it should.
NOTE. Fixing the washer takes a little mechanical ability (wrenches, socket sets, screw drivers, vice grips, short pipe wrench) and a solid desire to save some money.
All told parts cost less than $30 (I also replaced the old transmission oil with 80-90 weight oil from an auto parts store) saving over $125.
Sep 15, 2009 | Kenmore Washing Machines
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Kenmore series 80 washer: does not twist in the middle
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced.
Remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Part number is 80040
Let me know if you need more help.
Apr 01, 2009 | Kenmore Washing Machines
Need to remove the drive coupling on a kenmore 80 series washer
Remove the two screws holding the motor bracket braces, pop off brackets, pull it out.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Kenmore washer series 80-how do I remove the agitator
My Kenmore series 80 washer has sucked a shirt into the agitator and I cannot remove the agitator to free the shirt. How do I remove the agitator?. Do you have a diagram of the machine that I could look at to find it? The model is 238321000
Mar 09, 2009 | Kenmore Washing Machines
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Washing Machines Logo
126 people viewed this question
Sal De
fordexpert
Robert Rankin
