Question about Dell E176FP 17" LCD Monitor
My monitor is completely turned sideways.
My kids did something to my computer and now the screen is not showing up and down. It's been turned a quarter turn to the left. This happened once before, I just don't remember the solution. Thanks for your help.
  • 62 Answers
Please press CTRL + ALT + UP-key simultaneously. This will switch your screen to the correct horizontal position.
If this answer helped you, please leave a feedback, thanks!
Posted on Jul 18, 2010
My screen is on sideways and i cant put it back the right way
How to Rotate a Computer Screen 90 Degrees
Perhaps you built your own monitor, and the screen is displaying at the wrong angle now that it's all set up. Maybe you installed a new graphics card or driver, and it appears something has gone horribly wrong. It's possible you're just being creative, and think it would be cool to lay your monitor on its side and still be able to use the computer. Or, most likely, your cat or kids pressed some mysterious key combination which rotated your screen for you, and you can't get it back. Don't worry; getting your screen to rotate 90 degrees is easier than you think.
1 Identify in which direction your screen needs to be rotated. There are four shortcut key combinations, and each will rotate your screen so that the top of the screen is at the top, bottom, left or right side of your monitor; you need to know which combination to choose. Say you are you trying to correct a mistake, and put the top of your screen back where it belongs--at the top of the monitor. Or you are trying to rotate your screen because you are using your monitor differently than most people do, and want the top of the screen to be at the left or right side of the monitor, or even upside-down.
2 Hold down "Ctrl + Alt" and the "up" arrow key if you want to return the top of your screen to the top of the monitor. "Ctrl + Alt + Left Arrow" will rotate your screen so that the top of the display is on the left side of your monitor, and using the Right Arrow will put it at the right side. The Down Arrow will turn your screen upside down if your monitor is right side up. Make sure you hold all three keys down long enough; the screen may go back for a moment as the screen is rotated.
3 Open your "Control Panel" if nothing is happening, and see if there is an option to "Enable Screen Rotation" under your Display options. If not, you may not be able to rotate your screen. This is especially common with older computers, as they have older graphics cards or integrated video If you have a newer computer, you may need to have the graphics drivers updated in order for the shortcut to work.
Tips & Warnings
If pets or children accidentally rotated your screen, consider finding a way to better protect your keyboard not just from accidental keystrokes, but from pet hair and kids' spills. A keyboard cover might be in order.
Dec 02, 2011 | Computers & Internet
Computer screen
An upside down display is caused by unintentional pressing Ctrl-Alt plus the down arrow key.
Restore by pressing Ctrl-Alt plus the up arrow key.
ALSO
If the display is sideways then to change the display from portrait to landscape
Press Ctrl-Alt plus a left or right arrow key.
Some computers do not have this function.
Jun 21, 2010 | Gateway FPD2275W LCD Monitor
My screen did a 180 dregrees
tracey_brodi, Maybe try this! "ctrl+alt" keys and up-arrow or down-arrow. 12fixlouie
Jun 07, 2010 | Dell E176FP 17" LCD Monitor
Screen has turned sideways
Right click on an empty spot on the desktop and scroll down to either the Nvidia or ATI control panel. Once you are in the control panel, look in the left hand pane and look for something that says, screen orientation or screen rotation. When you select that it may give you the orientation in degrees of a compass or rosary. Make sure you place the monitor orientation at "0" degrees. This will bring the screen back to normal.
May 16, 2010 | Tatung LD23HL Monitor
Having turned on computer, windows loads, however desktop page shows horiontal on screen
Try to fight through this. This would be a setting either in your monitor, or in the display program you have installed on your computer for your monitor. Turn your monitor sideways if you need to, to fix this problem.
Mar 05, 2009 | LG 700M 17" CRT Monitor
Dell 17" monitor has turned 45 degrees
http://internetducttape.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Feb 08, 2009 | Dell E173FP 17" LCD Monitor
XEROX LCD flat screen monitor
Hold down the combination of keys "CTRL"+"Alt"+ "arrow keys" to change picture orientation on Windows, this will sort out the problem.
Oct 18, 2008 | Xerox XA7-172i 17" LCD Monitor
15" Dell monitor
You have your video card set to rotate the screen after Windows loads.
Go into your display properties using it's control panel and look for the rotate section. Set it back to 0 degrees. Make sure you click apply and then OK, not just OK.
Apr 18, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Monitor screen went sideways
Try the ALT key and the Up Arrow.
If that does not work, try CRT ALT UP and DOWN arrows till you can rotate your display.
Jan 29, 2008 | Computers & Internet
Dell E176FP 17" LCD Monitor Logo
Alun Cox
