Question about Kenmore Elite 45986 Front Load Washer
Dl / f HUH?
I get this code about half the time. I assume it is door lock failed, but it works the other half. Do I need to replace the lock? Help.
  • 101 Answers
Yes replace it 691581 - lever - mounting screws - connectors comes in a set ,it cost $20 .
Posted on Apr 21, 2008
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
Lid does not lock. When it DOES, it beeps and shows "dl" on the screen
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Getting message F DL. ASSUME MEANS DOOR NOT
IT APPEARS YOU HAVE A MAGNETIC CONTACT FOR THE DOOR,YOULL HAVE TO HAVE A REPAIR MAN REPLACE THAT CONTACT,
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Code dl-f machine will not start up, usually you hear the door lock and then water enters- but door does not lock which is why im thinking dl stands for door lock? i unpluged machine hoping it would reset...
Hello.
You are correct in that the fault code stands for door lock error. Here's the book answer:
Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Try pressing pause/cancel several times to reset it.
Best regards, --W/D--
Aug 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashes "DL" and "F"
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DL F signal
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replacing the door lock mech will fix this issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't start and we're getting the symbols ''F'' and ''dL''
Hi, this (F-dL), is a code that represents a failed door locking mechanism. you will have to check the wires leading from the control board to the door lock mech. test with a Ohm meter for resistance. if you pick up ant readings and, the door lock isn't functioning, it is time to replace this device.
In most cases, you will have to replace the door locking mech.
May 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
DL error code
DL is a 'Door Lock' error code.
A Door Lock Error occurs if the door cannot be locked. The Central Control Unit (CCU) will try to activate the lock 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism has failed
• Wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Central Control Unit (CCU) has failed.
There really isn't much you can do except replace the defective parts. The door locks have been troublesome and have replaced some. But there are cases where the CCU will develop an internal intermittent connection to the door lock causing it to work then not work. Check your owners manual for limited warranty on the CCU. The door lock only warranted for 1 yr.
Regards;
reg501
The FixYa Team
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
