Mcdevito75 here, If you changed the battery yourself, you"ll have to go back into the watch to make sure the buttons are presssing fully, and on the correct spot on the quartz movement, some times these button contacts get mis-aligned due to moveing the movement while replaceing the battery, you"ll also have to check the battery contact in the watch also, make sure the battery is being held fairly tight, the battery could have gotton loose. If you had the shop replace the battery, return to the shop for adjustments.
To set the time on your Timex 1440 Watch, please follow these directions:
1. Press and hold MODE (Upper left button)
(HOURS will flash and you'll be in Alarm Mode).
2. Press MODE again to enter TIME mode.
(SECONDS digits will flash.)
3. Press ADJUST (bottom right button) to set SECONDS to zero.
4. Press START/STOP (upper right button) to select MINUTES
5. Press ADJUST to change
6. Repeat to set Hours, Date, Month, and Day of the week.
(Go through 12 hours to set AM or PM)
7. Press MODE when finished
8. To display DATE from TIME display, press START/STOP
9. With DATE displayed, press and hold START/STOP, then press ADJUST to change display between DATE-MONTH
10. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12 and 24 hour format.
I hope you are now able to set the time on your watch! If you appreciate these instructions, please remember to rate this post.
--Sandy
