Question about Maytag MZD2766GES Side by Side Refrigerator
My maytag 2756g cycles frequently and does not get cold enough to get below 45 degrees in the refrigerator compartment. Does it need a recharge as I have put the thermostat on 9 and it still does not get cold enough and how do I recharge the compressor. I replaced the frost control and the compressor fan.
  • 1,711 Answers
If you can not get enough cold with the thermostat on low position then if the the problem is with freon or compressor then you have to check if the compressor stops and how often it stops. If it stop regurarly then you need to replace the thermostat. If the copressor works for hours without stopping then you need to check for freon gas. In ortder to charge your refrigerator with freon gas you will need to install a special suction valve on the pipe at the low pressure side. this valve is have a pin insert which will entered to the pipe and with the valve on it you can attached the freon hose with adaptor so you can charge the compressor.
If you are not familiar with refrigerator systems even if you are agood technician then I sugest to ask a pro doing it for you since you need special tools and adequate experiance.
Good Luck
Posted on Jul 18, 2010
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 | Freezers
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
My refigerator is not keeping things cool. It was working ok until, the other day, I turned down the termostat by 1 from 5 to 4, and there was an audible click. Sounded like a fuse blew or something, the...
Sounds like you just happened to be near the defrost cycle timer as it was ready
to start the cycle and the movement was just enough to start it. You should actually
be turning the cold to a higher number (from 5 to 6 instead) and make sure that
if you have an adjustment knob in the freezer that it is set to the middle and not
to "colder" This knob controls the vent which allows cold air into the fresh food
compartment below. If it is set all the way to "colder" it will almost completely
cut off cold air flow to the lower compartment. Also if you have a thermometer
use it to set the temperature between 36 degrees and 39 degrees in the fresh
food compartment, it should stay in the fridge for 24 hours for an accurate reading.
hope this helps.
Apr 10, 2011 | Frigidaire Refrigerators
I have amana DRS2662W- I had turned the defrost timer but now the freezer and the fridge are not cold enough- there is no ice forming, I can hear the compressor and fan behind but not cooling.
You should never need to advance your defrost timer. If your defrost is not working properly, the coil in the freezer compartment will ice up, blocking all airflow. All of your cooling is done there, even the refrig area, so you will never get down below appx. 40-45 degrees.
my first suggestion is to look at the back panel in your freezer for frost/ice build-up. If yes, unplug the unit, open the freezer compartment and let it thaw overnight. If it starts cooling properly, you have a defrost problem. It may be a bad timer(often), thermostat(less frequent), or bad defrost heater(even less).
Nov 15, 2010 | Amana DRS2663B Side by Side Refrigerator
Mod ED27DQ side by side refrigerator-Freezer works fine-refrigerator will not cool below 45 degrees
check the damper door located between the freezer and refrigerator compartment,if it is iced up it cannot open up and let cold air into refrigerator compartment from the freezer compartment,deice this part and then adjust the refrigerators cold control and see that the door opens and closes with controls adjustment
Jan 31, 2010 | Whirlpool Refrigerators
Top freezer quit freezing. Refrigerator works.
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Thank you for using FixYa
Jan 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Can this refrigerator be used in an unheated garage?
Yes, You can use most any refrigerator in an unheated area. Just be aware that if it is in a below freezing area for a long period of time that the cold may penetrate enough to get the refrigerator temperatures below freezing also.
Nov 18, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer quits working
Solution Found! The problem is when the temperature surrounding the refrigerator in the garage falls to < 45 degrees, the thermostat regulating the refrigerator will not call for the compressor to kick in to provide cooling (it's temperature requirements are being met). Since there is no demand, the compressor will not cycle, which is how the freezer is kept cold, and the freezer eventually warms up to match the refrigerator temperature. Frigidaire makes a "Cold Kit" that I ordered and installed from RepairClinic.com for $22 (Item #: 1037646; Description: Garage kit). It's basically a strip heater that runs off the control power to warm the thermostat and causes the compressor to cycle once to twice a day to keep the freezer frozen. After installation, the refrigerator stays at 40-45 and the freezer stays around 0 degrees.
Dec 02, 2007 | Bosch Exxcel KGV35421 Bottom Freezer...
Maytag MZD2766GES Side by Side Refrigerator Logo
66 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
