Question about Tunturi T30 Programmable Treadmill
Running belt has creased badly, will I need new belt ?
I had creases in running belt, have adjusted the tension & re aligned but two bumps still there, will I need a new belt, it hardly has any wear ?
  • 252 Answers
Wow, this is weird, I've just come back from the gym and the guys there were 'fixing' a crease on one side of the belt.
They had the belt off the treadmill, and put a wooden board on the inside, with some weight plates on them, a few wooden blocks on the inside, so the belt looked like it was the same height as when it is fitted and then a wooden board and weights on the top.
By the time I'd finished my session, they were refitting it and it looked good, you could still see a slight dent, but not a full crease.
Hope this helps you and good luck.
Posted on Jul 18, 2010
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
Tread belt is creasing. Have tried to adjust but continues to crease
belt is not aligned properly, have to be exact or belt will crease. If new seek warranty support. good luck.
Apr 10, 2015 | Exercise & Fitness
Serpentine belt
You should replace it, they get stretched, bruised or creased and after you run it one time, it is not new anymore.
Feb 14, 2014 | 2003 Jaguar X-Type
The belt on my New Balance 1400 has become kinked up. I tried adjusting it by loosening it up, straightening it out, then tightening it back up, but it kinks up again. Before it kinked up for the first...
Unfortunately once the belt has a crease that all she wrote. Belt replacement is the next step.Call Fitness Quest they are the makers of your treadmill @ 1-800-321-9236
Jul 31, 2010 | New Balance 1400 Treadmill
I have an Image 15.0Q UMTL31504 and the belt has
Go To Iconservice.com Click on manual input Image then M# IMTL31504.
Check the end caps to see if one of them is cracked before adjusting the belt. The crease cannot be straighten and 9 of 10 times it can be a hazard when walking so if you proceed using it in this condition BE CAREFUL!!!
Jul 30, 2010 | Exercise & Fitness
On my oki 5150 the printed paper develops a crease usally in the middle of the page. Usually about 4 inches long, with a small overlap that ends up in a crease ... it's starting to get sufficiently bad so...
If the paper under the crease has print and the fold is "glued down", it is most likely to be a problem with the fuser. Try removing it and look for evidence of warping in the pressure roller. If the fuser looks clean and tidy, go to the other end at check over the paper tray and paper feed mechanisim. It is possible the paper is catching on something at the start of the process. This is most likely if there is print over the crease but not under the fold.
Jan 01, 2018 | OKI C5150n Led Printer
When duplex printing I regularly get creased
Check the rollers for any mis-alignment. Try loosening them and re-aligning them again. It should'nt be too hard.
Dec 28, 2009 | Dell 5100cn Laser Printer
Crinkled ribbon
Try adjusting the head tension or ribbon tension.
May 19, 2009 | Intermec EasyCoder 3400e Thermal Label...
Printed paper is creased
First thing to check is try it with a fresh unopened ream of quality paper, paper with too much moisture content, drys out and goes wavy when it runs threw the fuser roller at rear (180 deg), otherwise it will be the fuser rollers themselves causing your problem, which means that you need to replace fuser assy
Dec 05, 2007 | Samsung CLP 300 Laser Printer
Tunturi T30 Programmable Treadmill Logo
1,526 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Marvin
Marvin
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
