Question about Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW
My freezer door was propped open all night long. The food was still very cold when we discovered it. It's been almost 20 hours and most of the food is frozen, however it feels very hot on the outside. Is it ok?
  • Frigidaire Master
  • 909 Answers
Being hot on the outside is totaly normal. If there is an ice build up, switch off and totally defrost the freezer. If not, no harm done.
Posted on Jul 18, 2010
We do not use the freezer on our Whirlpool fridge freezer. It has recently started to turn itself on, thus the alarm sounds as the freezer is not down to temperature. This tends to happen in the middle of...
The freezer is where the cold air is generated. It knows that is not logical to turn off the fresh food side so it determines that it needs the cold from the freezer side, so it over rides the error and will attempt to start. Turn your freezer on to a mid way setting ans give it a few hours to comply.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 25, 2017 | Whirlpool Freezers
We accidentally left our upright 20 cf frigidaire freezer door open for 24 hrs, all the food spoiled and now the freezer is not freezing and only cooling. Any ideas of what is wrong? thanks
THE UINT IS FROZE UP, YOU WILL NEED TO DEFROST IT. USE A FAN TO BLOW INTO THE FREEZER PORTION , AND HAVE LOTS OF BIG THIRSTY TOWELS HANDY .. THIS WILL TAKE ABOUT 2 HOURS TO DEFROST, WIPE EVERY THING INSIDE THE UNIT DRY !... JAY THE POOL PUMP MOTOR REPAIR GUY FLORIDA
Jul 28, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer defrosted and the motor won't start back up.
From what I can gather, you have a self defrosting freezer and the "motor" you speak of is the fan inside the freezer. If this is correct, do this:
Unplug freezer. Unload all food into coolers or other freezer space. Leave freezer door open for a day to allow it to manually defrost. Plug freezer back in after minimum 24 hours and confirm fan running and cooling before loading back up with food.
Mar 28, 2009 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore freezer peeing on my floor
  • if the door was not closed correctly for a while then a lot of condensation will be accumulated on the freezer coils.
  • then when going into defrost it melts this ice/frost and overflows the pan or container under the machine which relies on evaporation to dispel  of the water.
  • empty the pan under the refrigerator if you can, then give it another day, it will get back to normal.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Fridge freezer
did your friend use a knife to prize off lumps of ice? i bet he/she did and has punctured the evaporator. if so, not repairable
Jul 04, 2008 | Zanussi Freezers
Freezer Thawing Out
This will not cause a freon leak and it is possible that the door was left open, but to be certain that you don't have a defrost issue, follow the guide below to diagnose any problems. Also the warm walls are normal during compressor run times.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0047_3.asp
If your freezer cools but doesn't get cold enough, it may have a problem in one of several areas. To better understand the proper operation of a freezer, read about freezers in the How Things Work section of our website.
In a self-defrosting freezer, poor cooling often results from a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel inside your freezer. But if you see any frost or ice build-up on the inside walls, ceiling, or floor of your freezer, it's a sure sign of frost build-up. And that's a sign of a problem with the self-defrosting system.
Freezers should self-defrost three to four times in 24 hours. But if a component in the self-defrosting system fails, the freezer continues to try to cool, instead. Eventually, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There's still some cooling because the coils are frozen. But with no air flow over the coils, the cooling is quite limited and the freezer isn't as cold as it needs to be.
An easy (though often inconvenient) test of whether the problem is with the self-defrosting system is to remove all of the perishable food from the freezer, turn the thermostat to Off, and leave the door open for 24 to 48 hours. (Keep several towels handy in case the melting frost and ice overflows the drip pan). This "manually" defrosts the freezer. When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the freezer then cools properly, it indicates a problem with one of these components in the self-defrosting system:
  • The defrost timer. To test this, manually advance to the defrost cycle. The unit should advance itself out of the defrost cycle in about 45 minutes.
  • The defrost thermostat (or bi-metal switch). This thermostat allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees (depending on its design). This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on.
  • The defrost heater. You can test this for continuity using an electrical meter.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 19, 2008 | Frigidaire Freezers
Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW Logo
263 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
