Question about Whirlpool Duet GHW9150P Front Load Washer
All water is not draining out of washer and a fault F2 comes up on the display screen
    President:
  • 1,382 Answers
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Posted on Jul 18, 2010
Why is it displaying f2 code and will not drain?
The F2 fault code indicates a problem with the washer's drain system, and you must troubleshoot the problem to determine how to fix the washer and clear the code.
Clogged Drain Hose The drain hose on a Kenmore washer should remain free of obstructions so the water drains from the washtub. the drain hose behind the washer can impede the flow of water from the washer. A drain hose inserted more than 4 1/2 inches into a floor or wall standpipe drain system can cause the water to siphon back into the washtub.
Stuck Water-Level Pressure Switch Your Kenmore washer uses a water-level pressure switch in the control panel to detect the level of water inside the washtub. You can find the pressure switch behind the control panel in top-load models or attached to the inside wall of front-load models. The round switch is approximately 3 inches in diameter with a clear or black plastic tube connected to the bottom or side of the switch. The tube runs from the pressure switch to the exterior washtub. As the water fills the washtub, it changes the air pressure inside the tube and lets the switch know when the water has reached a predetermined level. A stuck contact on the pressure switch can stop the advancement of the wash cycle and keep the water from draining. A few taps on the top of the switch with a screwdriver handle can release the contact and fix the problem causing the F2 error code.
Jun 12, 2015 | Washing Machines
F2 fault
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair.
Jan 21, 2013 | Siemens Washing Machines
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Stopped in middle of cycle with F2 fault flashing on timer screen
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
These videos show what to do
More repair photos and a service manual with error codes and component ID are here
Feb 06, 2011 | Whirlpool GHW9250M Front Load Washer
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washer is giving a code of "F2" & not draining properly.. any idea?
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump.
Whirlpool F2 = Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:
(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 flashing on display screen washer won't continue cycle????
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Oct 12, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
What is F 2???
This is what the code F2 means for whirlpool duet washer.
Long Drain
flashed.
the F/02 error code will be displayed.
Potential Causes
running.
Mar 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
66 people viewed this question
Dan Webster
Dan Webster
Sal De
