Question about GE Monogram Side by Side Refrigerator
The temperature is rising. In freeze temp set to 0. It is 34...Manual says no need for routine condenser cleaning, tried to vacuum it, but no improvement overnight in temp. Doors are properly closed.
  • Mike Smith
    Mike Smith Jul 18, 2010
    model number needed to help .
  • way2cute26 Aug 05, 2010
    Ok we have a kenmore upright freezer Model # 253.26062103. We got it brand new about 3-4 years ago. It was working fine til about 2 weeks ago when the ice cream became soft and high temp alarm started going off..everything else stayed frozen. my husband checked and there was frost build up on the back wall which we decided to take evrything out of the freezer and self defrost it because we thought since the outside temp was unusually high maybe the freezer wasnt able to defrost properly. We did this and plugged it back in a few days later. We put a thermometer inside the freezer and it is only reading 20 degrees F or -5 celcius. Still not cold enough. We then replaced the electronic control panel which also houses the defrost timer and that did not help raise the temp. Alarm still going off when switched is turned on. We then decided to have a repair service out...they said it was the defrost heater, timer and thermostat, we said we already replaced the timer, so we bought the other 2 parts and replaced them. well it is still not cooling properly and we have no idea what to check next...This is costing us a ridiculous amount of money and we can't get a solution...Any help would be appreciated.
  • 4,070 Answers
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).If it's heavy ice build up...
Could be a defrost problem.
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Jul 18, 2010
  • RottWhiler Apr 18, 2011
    Clearest answer I have seen in a very long time. Concise to the point and understandable! Huge Kudos, Woodchuck789!
Why is it beeping?
if temperature is rising, you will get a beep. you need to find why the temp rising. Clean condenser coils and make sure that condenser motor is running art full speed.
Sep 01, 2015 | Samsung RS275AC Refrigerator
Why does the temperature on my ge fridge keep changing to warmer temp?
Make sure the condenser is clean and clear, and all fans are working as they should. Also check the freezer section for signs of ice build up. A good defrost and a cleanup usually does the trick!
If it's in direct sunlight, try to limit the heat with a blind.
Jun 14, 2014 | Maytag MZD2766GES Side by Side...
How do I get the right temperature in a beverage air BM 23 Kegerator
either a problem with the thermostat or the probe for it has been dislodged and getting a false temp reading
May 18, 2014 | Beverage-Air BM23
I have a Prestige fridge/freezer model prt325ffcs, 18months old, and the problem is that the freezer compartment is not remaining cold , the super freeze function works reducing the temp. to -25 , but as...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Refrigerators
"service" flashing also what seems to be an error
Service flashing- 1. Ice maker not working 2, Rise in temperature 3. Condenser needs cleaning
To Clean Condenser 1. Remove Grille 2. Brush with a soft brush 3. Vacuum being careful not to bend fins.
Jul 07, 2011 | Sub-Zero 650/SRH Stainless Steel
580.53701300 low temp dehumidifier freezes up, no water, fan & compressor run constantly in basement 61 deg. F. Has sensor been declared defective and will Sears remedy by free installation &...
Although, this was a poorly designed unit, manufactured by Whirlpool for Sears's Kenmore line, I'm not aware of any recalls due to a defective sensor. I can tell you, that although the air temp in your basement may be 61 degrees F, at floor level the temperature can be as much as 5 to 8 degrees colder. This definitely, would affect the operation of the dehumidifier. Also, a dirty or clogged air intake filter will cause the unit to freeze up. As will dirty condenser coils. Cleaning the coils twice a year, is recommended routine maintenance. And regular cleaning of the air intake filter is a must.
What I would suggest, is that you perform the maintenance mentioned above and move the unit upstairs where it warmer and run the unit there for several hours. If it collects water there, with the humidity extraction level set at 35%, then you will know the unit works as it should and that it needed the routine maintenance and the warmer air temperature. Do not perform any maintenance until the unit has completely thawed and the unit is unplugged from the wall outlet.
Hope this helps you to troubleshoot and solve the problem.
May 26, 2011 | Kenmore 53701 Dehumidifier
AC COOL WITH LOWER AMBIENT TEMPERATURE AND BLOWS WARMER AIR AS OUTSIDE TEMPS RISE.
MAKE SURE THE CONDENSER IS CLEAN AND THE FAN IS WORKING. DOES EVAPORATOR FREEZE UP? IF DOES LOW FREON LEVEL OR BAD EXPANSION VALVE
Aug 06, 2008 | 1988 Ford F 150
Refrigerator freezes things the freezer works fine:
Most common is a dirty condenser coil. If you have not cleaned it recently vacuum and brush the coil underneath and the back bottom compressor compartment. Blocked air flow will cause erratic temps in the refrigerator section.
Jul 28, 2008 | Jenn-Air JSD2789GES Side by Side...
Beverage-Air Freezer Model KF-24
verify that condensers ain't clogged with dirt, condenser fan is running all the time and set the thermostat to the coldest setting. if temperature keeps rising suspect dirty condenser of deficient condenser fan. if compressor runs and no cooling after condenser cleaning. suspect a refrigerant charge problem. hope to be of assisit
Apr 26, 2008 | Beverage-Air 20.7 cu. ft. / 586 liter...
GE Monogram Side by Side Refrigerator Logo
513 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
