Question about Canon PIXMA iP4300 InkJet Photo Printer
Amber light flashing 4 times
Lost my manual; the paper suddenly started jamming, and now the amber light flashed 4 times in a row. I know that means something, but without my manual, I don't know.
Is there an online manual?
  • Canon Master
  • 13,433 Answers
Yes there is. Geting now.
Posted on Apr 21, 2008
Amber "Paper" light constantly flashing. It has
This light sequence means that the printer prompts you to load a single sheet of print media in the manual feeder. What you can do is load paper into the manual feeder and press Continue to resume printing. Press and hold Cancel to reset the printer.
For further assistance, please call Lexmark Technical Support.
Apr 26, 2011 | Lexmark E250dn Laser Printer
The amber light with the triangle next to it is flashing please help!!!
That is the ATTENTION state. Four things can cause it to flash.
1) empty paper tray
2) door open
3) paper jam
4) misfeed from tray.
Press the GO button(the diamond). If it still doesn't work, check for a paperjam.. Also try printing from the manual feed tray.
Aug 21, 2010 | HP LaserJet 1160 Printer
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
I have a acanon pixma mp210.. amber alarm light
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Amber light is blinking, error message when printing
Generally means that you're out of ink in your ink cartridge. Note that the NUMBER of times it flashes is significant: if it's 2 or 3 flashes at a time, then it's a paper problem (jam, out of paper, etc.), otherwise it's an ink problem (replace the cartridge).
Oct 14, 2009 | Canon PIXMA iP1600 Printer
Flashing amber light on printer
As you give print command check what is the error msg flashes on ur PC.
Next check whether any paper piece is jammed inside the printer, dust it with Airblower so that cleans out.
Third check the ink levels in both color and black cartdriges.
Regards
Oct 03, 2009 | Office Equipment & Supplies
Triangle symbol on our printer with a AMBER LIGHT FLASHING?
There is an issue with the media/paper. First thing is to make sure there is paper, and if so, that it's touching the intake rollers. Next is to check for jams, which are usually under the imaging drum. Open the front lid and remove the drum (it's in the front; follow the directions shown on the label on the front right.) Also, check for jams where the paper exits the printer.
Final two things. The lid could be ajar - simply push down firmly to ensure all the contact switches are closed. The last thing is an issue with the fuser, which may require replacing it. I highly recommend getting the service manual from HP, as it is easy to follow and has extensive troubleshooting.
Jul 01, 2009 | HP LaserJet 2550n Printer
Oki c3400n all 3 lights are flashing amber 2 times a second
i suspect an ouput sensor actuator beeing dislodge in the process of paper removal
Mar 18, 2009 | OKI C3400n Laser Printer
Not printing
There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
Thoroughly check the paper feed path.
If not working, then check/clean the rollers.
Jan 20, 2008 | Kyocera FS-720 Laser Printer
Real Basic Question
Unfortunately, that top light isn't very helpful as it's an indicator for several problems (IE: Front door open, out of paper, incorrect/improperly installed print cartridge, etc.), so really, the only things you can do since you've already eliminated the 'out of paper' scheme is make sure the front door's 'button pusher' is still attached and pressing the internal button in the printer, and re-seating the print cartridge. All the help I can offer, I'm afraid.
Manual: http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/bpl04109/bpl04109.pdf
-Backu
Jan 19, 2008 | HP LaserJet 5L Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
425 people viewed this question
old marine
old marine
