Question about Marantz SR4001
My Marantz sr 4001 receiver has no output. Is
My Marantz sr 4001 receiver has no output. Is there a a fuse on the output for the speakers?
  • 3 Answers
My friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
  • 163 Answers
There is no fuses for the speakers. Check setup. If the receiver has 7.1 channel input try to connect a source there so you can check output (amp) section and the speakers.
Posted on Jul 21, 2010
No sound from TV
check the fuse output line in the speaker! or maybe you are in protect mode! checkout the speaker, maybe you have defective speaker, thats why your unit in protect mode, thats why no sounds coming out!
Oct 06, 2007 | Marantz SR-6300 Receiver
I have bose 901 series 2 speakers, marantz 8200 and 2 marantz ma700 monoblock amps how do i hook everything up? Thankd
Do you mean SR-8200? You can't omit the details of a model number if you want a good answer.
Assuming it is...
http://www.retrevo.com/support/Marantz-SR8200-Receivers-manual/id/511ci775/t/2/
Run the 901's with the Active EQ between the receiver Front L and R Pre-Outputs and the mono block amps, one chanel to each.
Pre Out Channel X >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> Monoblock IN
http://community.klipsch.com/forums/storage/74/1341919/200w%20mono%2005.jpg
I can't find a manual for the MA700. Set them up to a certain volume and then use the speaker setup routines of the SR to match everything up volume-wise. Control will be in the AVR.
Aug 22, 2011 | Bose 901 VI Main / Stereo Speaker
I'm having a problem with sound from a Marantz SR48 MKII. I have a pair of Klipsch monitors connected to the "system 1" outputs on the Marantz and a Polk PSW100 connected to the "system...
I'd say you DO need to evaluate how the PSW is attached. I can't find the specific manual for it but the prescribed way for most subs that accept speaker level inputs (and HAVE speaker level output terminals) is run one pair of speaker outputs from the receiver to the sub and daisy-chain the Klipsh speakers from the sub.
Aug 19, 2011 | Marantz SR-48 Mark II Receiver
My sr 18 has no audio output,on all speakers,but video is good.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR-18EX-Receivers-manual/id/511ci766/t/2/
Headphones connected?
Disregarding specific sources, how does it do with test tones?
Jul 09, 2011 | Marantz SR-18EX Receiver
My marantz SR 7400 suddenly shuts down or goes into protect mode shows code CKPWR5
Most likely you have a speaker short, you need to check the ohms on each speaker disconnected from receiver if they are 8 ohms they should be close to that on the meter no more than a 1 and half ohm varience to what the speaker ohms says on the back. If they are ok you need to disconnect speaker wire from receiver and check for a short in the wire by connecting ohm meter leads to ends of the speaker wire you should get no reading if the wire is good. If this is all good you have a bad output transister in your receiver, but i dout this is the case because these transisters normally short to ground and blow a fuse. Hope you solve your problem good luck
May 24, 2010 | Marantz SR-7400 Receiver
Marantz sr8001: standby light blinks rapidly,
Hello there Ed.
For anyone that has ever had such an issue with a MARANTZ SR series (6001. 7001. 7002. 8001...etc...) issue a question and I do HAVE the answer.
I could be just anything, or just the low quality binding posts used by MARANTZ for that.
Please describe to me in details how you've connected your speaker wires at the back, and give me description when and how did this problem came up.
Kind regards
Evangelos
Oct 17, 2009 | Marantz SR8001
Marantz SR-940
Just finish repairing Marantz SR 940 with no sound output. Problem was a clamped speakers relay located behind the speakers lugs (red and black post connectors). To reach the relays you must remove the little circuit board behind those colored connectors et unsolder the posts. There is 2 relays, one for A set and one for B set of speakers. Very EASY when you know the solution!!
Nov 24, 2008 | Audio Players & Recorders
Marantz SR 7200
Most often it is due to improper speaker loading. In other words, it needs to have from 4 to 8 ohms speaker load and you wired your speakers in parallel when they should have been wired in series. What would have been an 8 ohm speaker load in series, turns into a 2 ohm load when in parallel. And with dual voice coil speakers you just compound the problem. And don't even get me started on bridged outputs.
Anyway that is what usually causes an amp to fry. Good luck.
Aug 03, 2008 | Marantz SR-7000 Receiver
Marantz SR4001 Logo
522 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
