Question about Husqvarna Designer I
Embroidery says device not connected
When I try to load my own design I get message...device not connected and machine will no start
  • 201 Answers
Where are these messages appearing? In your computer embroidery software or on the machine's screen?
Posted on Aug 11, 2010
My Machine have an error message coming from the screen "BROKEN DESIGN DATA WILL BE DELETED FOR SYSTEM RESTORATION" Whats is the solution for this error?
I will need more information on make and model of embroidery machine this is.... a system reset need to flush out the memory and delete improperly saved or partially loaded embroidery designs.
Cheers,
Embroidery Services
San Diego, CA
Jul 03, 2016 | Sewing Machines
I have a 3D/ Pfaff 2170 Creative & I'm using Windows XP. No device found error. I can not transfer the embroidery design to 2170 Pfaff. Help!
Sounds like you don't have the device driver on you computer for the sewing machine. Question: Did it ever work? If it used to work but doesn't now, try using a different cable from the computer to the sewing machine. You can also try rebooting the computer (with the sewing machine connected and powered up) to see if it will locate the machine.
Dec 19, 2014 | PfaFF Sewing Machines
I just bought a 730 Bernina sewing and embroidery system. I just tried to send design to embroidery machine and got the message I have no memory left. How can I add memory?
My suggestion is to transfer unused designs onto a USB stick or connect your sewing machine to your computure and save them.Then you can delele them and have enough space to put additional designs on your machine.You can call your dealer and ask, but I dont think it can be done without sending it back to the manufactor. If it can be done it would know doubt be fairly expensive.
Nov 20, 2014 | Bernina Sewing Machines
How can I send designs from my PC to my Toyota 830 embroidery machine when my Pantograms software/hardware is no longer working?
Some of the Pantograms software programs require a USB dongle connected to the computer. However, the driver for this dongle has to be installed before you install the software or connect the dongle. I suspect you may not have installed the driver or the dongle is missing.
Assuming that the dongle is connected:
Close your embroidery software program and all of the Pantograms software, including the Network C software, on your computer and remove the USB device. Put the software install CD into your machine's optical drive. (If your new machine doesn't have an optical drive, get a USB optical drive or copy the files from the CD to a 1GB+ USB flash drive at another computer with an optical drive.) If Windows XP starts the autorun routine for the CD, click Exit. Then double-left click on My Computer to launch File Explorer. Go to the CD drive (or USB drive if you used the work-around) and double-click on it. Open the Rainbow Drivers folder and then open the XP folder. Double click on the program: setup.exe . Choose Complete install as the program executes. Then close File Explorer when the install is done. Now insert the USB dongle and follow the on-screen message about New Hardware found to install the Rainbow driver from C: .
If you do not see the New Hardware found message, try putting the dongle into a different USB port. (Make sure to avoid USB hubs - they can add to USB device issues.) If the dongle doesn't work at any port, you may need to use a different method. There is a flash reader available for connecting a USB flash drive to the Toyota 830 here: http://www.plrelectronics.com/lab/usb_reader.php . (Scroll down to the Toyota machine section. This isn't cheap but it is cheaper than some of the newer embroidery software packages.)
I hope this helps.
Oct 26, 2014 | Sewing Machines
Hi. I have a commercial one head tajima embroidery machine. I was sewing and realized I had no thread on one bobbin so I stopped the machine. Instead of continuing on, I decided to start all over with a...
Your new embroidery program has to be loaded first. The 2b7 is referring to needing instructions or in other words the embroidery program has to be loaded. Shut the machine down and turn the machine back on and load just as before.
Jul 06, 2017 | Sewing Machines
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
I have a Toyota 830 embroidery machine. I am getting RS232C Connect and Internal Communication error messages. I have the serial cable from the embroidery head connected to my Compaq PC using a Belkin...
if you have pantograms software I'd like to have you make a copy of it if it is ver 7.55 7.60. I'll pay you for doing it. My original copy isn't readable, and I have to reinstall it.
Thank you
.leedon@prolog.net
Aug 09, 2011 | Toyota Sewing Machines
EMBROIDERY STOPS IN MIDDLE OF DESIGN. PRESS RUN AND IT WILL RUN FOR A SECOND AND STOP AGAIN
Are you sure you are not "double-pressing" the Start/Stop button? The machine might think you have said Go and Stop straight after? Try embroiderying using the foot pedal - see if that works for you. I guess you are aware that the machine will stop for thread colour changes. Do an experiment on any old piece of fabric - load the design and press the Stop button (not the one mentioned above, but the one of the left-hand side above Fix). The light should go out. This will eliminate the colour changes - the design will sew out in one single colour only. See if it keeps running and completes the design.
I would also "park" the embroidery arm, turn off the machine, remove the arm, replace the arm, turn machine back on and try again. Sometimes it just needs to start all over to get things back on track.
Jun 14, 2010 | Husqvarna Designer I
Husqvarna Diamond Embroidery unit problems
Make sure that the red disk (smaller than a floppy) on the underside of your embroidery unit has been removed. Remove and discard the red disk. It is used for shipping purposes only. Joyce
Jan 10, 2009 | Husqvarna Viking 1
Embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Dec 18, 2007 | Husqvarna Viking 1
Sewing Machines Logo
57 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
