Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP 7410 will not scan either from feeder or from glass. It complains of Fuser problem. Also although I have replaced the Color cartridge several times, anything printed in color comes out with colors faded and washed out. Please advise
  • 146 Answers
Special lubricant should be used in some cases of this problem.
Try http://www.printertechs.com/tech/error-codes/error-codes-50-59.php
and check your problem
You should replace the fuser call your customer care and ask for a support and replace the fuser.
Posted on Jul 18, 2010
How do i stop my sharp mx 4111n printer from printing with line on the paper
does this happen when printing? or copying? if printing check the fuser, image /drum unit What color is the line replace that image unit, if copying does it happen thru the doc feeder ? if so place on the big glass and make a copy if it goes away the its the doc feeder slit glass that is small glass use by the doc feeder, big glass not used by the doc feeder when copying or scanning
Feb 17, 2015 | Sharp Office Equipment & Supplies
Horizontal lines
Most lines will either come from laser cartridges, or and most likly the fuser. If you can see the fuser rollers, see if they have wear marks. If so fuser or rollers need replacing. If a multifunction copier with a top glass check the what is called slit glass(small glass where paper goes over when fed from the document feeder.
Jul 23, 2014 | Brother MFC-9320CW Color Laser Printer -...
Insert HP color inkjet print cartridge 99 into HP OfficeJet 7410 I am replacing the HP 97 color print cartridge with th 99 print cartridge (both are color). The 99 will not go in all the way. I notice the...
The HP 99 cartridge is used if you would like to print photos. The HP 99 replaces the HP 96 (black) cartridge in your printer. The HP 99 cartridge has black, photo magenta, and photo cyan inks in it. When you pair this with the cyan, magenta, and yellow in your HP 97 (color) cartridge you have the full set of photo colors represented.
Jan 13, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
When scanning several pages of a document some pages scan fine, some you'll hear a draggin noise and there are smudge lines thru the document (putting thru feeder). Other times when you place 1 copy to be...
Well, if both feeder and pattern glass also having line on print, suspect hardwares problem...
U can check below items:
1. drum
2. laser unit
3. fuser unit
Mar 03, 2009 | Office Equipment & Supplies
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Color cartridge problem
Check the color side of the carriage....there is a metal piece in there that breaks free from the side and will "stab" the circuitry board that the cartridge comes in contact with...you will probably see a hole in it...I have replaced several print carriages...fairly common problem with all of the HP printers that use the 96 and 97 cartridges...hope this helps
Apr 30, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Good, so u are having probs in ADF. Open the cover, lift the rollers and u can see the scanning glass. Take a lint free cloth and clean it. it will be ok.
Feb 03, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 Scan feeder jam
ill see if thera sev maneul out for u best to unplug it all 2 min then back on with latest drivers what kinda paper are uusing sum are picky to thin ect
Jan 30, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 streaks on scanning and copying
First you need to determine if it's doing from both the  top and the glass.
1-assuming you are using the feeder to fax,copy or scan (the part that automatically picks up the paper) it comes out with a streak. Make a copy putting the paper on the glass and look at the copy. Does it have the streak?
2-lift the top and look to the left there should be a small 1inch glass, this is where it makes the copies from the feeder, is there a dot or white out or is the glass dirty? that's your streak, the paper is moving to make the copy,so the dot now looks like a line as opposed to making a copy on the glass it just sits there so a dot will stay a dot.
2- Clean with water or alcohol.
Oct 23, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
35 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
