Question about Yamaha YSP-1 System
Hi have had yamaha ysp1 speakers for 5 years had no problem today no sound they wont turn on Del.
Leave the solution for yamaha ysp1 crackling when first turn on.
Check for any loose solder terminals at its main power amp section circuit. Contact any service technician. Electro help
Nov 20, 2014 | Yamaha YSP-1 System
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
My Yamaha psr-500 wont turn on. When I push the on button the speakers make a popping sound and when I hold the on button down I get static through the speakers along with 3 notes one after the other
Is this on mains or battery? This keyboard must be nearly 20 years old, it's done well! If you have batteries in but are using mains power, the power adaptor could have failed and not enough juice left in batteries to work. Try new batteries and try without any.
Aug 09, 2013 | Yamaha Music
Trying to connect to TV but only center speaker works. System came with Dell Computer. Have 5 speakers and subwoofer????
Hi there bud ...Are you sure you using the RCA Cables , and not just the Cables that came with SPeakers?
Also make sure THat your T.V can handle 5.1 Channel Sound Speakers..
Hope you come right bud
Happy new year
Jan 07, 2010 | Altec Lansing ACS 45.1 Computer Speakers
Yamaha xs750 starting problem
You need you carb cleaned, air filter cleaned or replaced, and new spark plugs.
I bought XJ750 years ago, not running, cleaned the carbs, installed new spark plugs, and rode her for 5 years
Aug 22, 2009 | Yamaha TX 650 A Motorcycles
Yamaha YSP1
We have the same issue. I owned the unit for about 2 1/2 years before it quit working. The Yamaha YSP-1 has been sitting on my shelf for the last 2 years now collecting dust. If anyone finds a solution, please let me know
Dec 22, 2008 | Yamaha YSP-1 System
RECEIVER WILL NOT TURN ON.
first you have to test separatly your speakers outputs
disconnect all wires speaker and speakers, turn on your reciever and look if you still have the same problem «CHECK SPEAKER WIRES alert» if yes you have to go to a specialist to fix it... if no test one line after one line with and without speaker connected until the problem reappear to locate the bad line or bad speaker.
Apr 26, 2008 | Yamaha HTR-5650 Receiver
I have a yamaha rxv2500 no sound coming out
check your speaker wire and speaker for open circuit.
Nov 28, 2007 | Yamaha DSP-A1000 5-Channel Amplifier
Das TV make cracking and poping noise when you unhook it from receiver?
Sep 30, 2007 | Sony STR-DE197 Receiver
No sound in rear and center speaker
Check to see if you have sound by selecting 5 chnl speaker setting buy pushing the program button on the amp. you should have sound comming through all speakers.
Oct 10, 2006 | Yamaha HTR-5440 Receiver
Yamaha YSP-1 System Logo
52 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
