Question about Microsoft Xbox 360 Console
Live when i try to connect to live it says not connected and it says MTU failed??
  • dsantiago88 Sep 30, 2008
    i use to be able to get onto xbox live until an but now i plug up the live into the modem and it says MTU failed.. how do i fix the settings on the modem; it says i need at least 1364 MTU space. but i dont know how to update the settings.
MTU failure is usually caused by having too many computers or consoles connected to one internet connection, or by a router that isn't compatible with live. Try hooking the 360 right to your modem and see if it works. If it does, then try changing the settings in your router.
Posted on Apr 24, 2008
It's when Xbox live is temporarily down
For repairs and the etc.
It'll be working now.
Posted on Apr 23, 2008
Not enough mtu to go to xbox live at hotel
An MTU is the largest physical packet size, measure in Bytes that a network is capable of transmitting.. If messages are larger than the MTU they are divided into smaller packets before they can be sent. All networks have different MTU's which the owner of the network set at what they want to set it at. 576 is a very common MTU if you connect through PPP. 1500 is the most common MTU for Ethernet connections. The Xbox Live system requires your network to have a certain Maximum Transmission Unit (MTU). MTU values are important to the performance of online games. If this test fails, you can adjust the MTU setting on your network router or equivalent device to resolve the problem. Xbox live requires the network you use to have a maximum MTU. This is key to online gamesing. If the MTU fails then you have to adjust the router you are using. If you cannot access the router to adjust the MTU the you will not be able to play online games.
Mar 22, 2011 | Microsoft Xbox 360 Console
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
I can't connect my Xbox 360 into LIVE because the
This option is available via the web interface under the WAN Settings screen.
Nov 29, 2009 | 3Com OfficeConnect Wireless Router
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 06, 2009 | Belkin N1 Vision Router
Xbox live cant connect mtu failed
This appears to be a common problem, most likely due to the recent Xbox Live server maintenance. Nothing we can do except for wait until Microsoft fixes things on their end.
Hi can you please help me i was on xbox live tryed to connect with a router and now my 360 is askin for an ip address,but we do not no it can you please help thanks Paul
Aug 02, 2008 | Microsoft Xbox 360 Console
Mtu test is failing
I've had the same problem and struggled with it for hours... If your on the Comcast network, there seems to be problems with adjusting MTU. I have a Dell 2350 router and that particular router cannot have MTU modified. Also, sometimes the MTU is effected by computers or phones in the house being on. One more suggestion, try a gaming router. Good ones start at 90 dollars, somewhat expencive but well worth it.
Jun 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 live states MTU failed
for some reason i cant connect to live, it says that my mtu has failed. any surgesstions how i solve this??
May 18, 2008 | Microsoft Xbox 360 Console
Mtu failed
what kind of router are you using to connect your xbox 360 to? usually you can define the MTU size in the router configuration.. default for xbox 360 live is 1364 ... check out your web configuration on your router to see if you can change this!
May 02, 2008 | Computers & Internet
Xbox live connection?
When the Xbox live fails, it just means XBOX Live is currently down in your area. Give it a day then try again. If the problem continues, call microsoft.
Apr 11, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
94 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
