Question about SanDisk Sansa E280 MP3 Player
My sansa keeps restarting after approximetly 10 seconds, it started, when I tryed to charge it, I bought new battery and it keeps doing it off pc cable too...
  • cergow Jul 20, 2010
    and how can I update firmware, when my pc can´t recognize sandisk and it´s demanded by program that I connect player to pc to start working with firmware..
  • cergow Jul 26, 2010
    but my pc can´t recognize player in such short time till it restarts again, so I´m not able to update firmware
  • 68 Answers
Update firmware and tri download firmware from sandisk
site
Posted on Jul 19, 2010
  • 2 more comments
  • cergow Jul 19, 2010
    Thx for advice, , but my PC can´t recognize player, because it´s restarting itself earlier than it can communicate with PC...
  • robin_yohann Jul 20, 2010
    UPDATE IT FIRM WARE
    update it firm ware
  • robin_yohann Jul 26, 2010
    update software eg firm ware
Can't get sandisk sansa fuze+ to turn on, what do I do
Hold the on/off slider for 30-40 seconds and then release to reset the device. Then try turning it on. Also, sometimes if the battery is low/dead it will take longer than 3 hours to charge up. If it does not turn on after the reset you might try letting it charge for a day or so and try again. If it doesn't work after all of this, it should be returned to where ever you bought it for a replacement.
Aug 13, 2014 | SanDisk Sansa Fuze MP3 Player
My Sansa c250 won't charge properly. Initially when I bought it, I used it with a Windows XP PC, no sweat. That computer died and I began charging it with an OSX instead. It worked for a while, but after a...
I had a similar problem. My Sansa c250 would charge, when plugged into the computer. It would read that it was writing but the computer did not recognized that the Sansa c250 was connected. I switched to a different USB port and got the same results. I then realized that the two ports I was using were 1.0 port and idmedeatly when inserted in the 2.0 port it began charging and the computer recongized the Sansa c250. I know this won't solve every charging problem one may have. Changing the battery would be easier in some cases. Especially if they were sold like the AA or AAA.
Jun 08, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Battery won't hold charge very long
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 20, 2008 | SanDisk Sansa e250 MP3 Player
I can not get it to charge or power on.
colon and Jaime - that is normal behavior for the Sansa
inuy:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Dec 19, 2008 | SanDisk Sansa Clip MP3 Player
I need installation CD and it only shows a white screen
Software available from Sandisk's website
-Tha Mp3 Doctor
Dec 06, 2008 | SanDisk Sansa e260 MP3 Player
Can't get sansa sandisk mp3 player to charge
Battery does not have to be depleted, there is a reset as well as a Recovery Tool from Sandisk's website. You will need to upgrade the firmware if your computer is running Windows Vista.
-Tha Mp3 Doctor
Battery not charging
Use the volume + method listed below:
-Tha Mp3 Doctor
Sep 02, 2008 | SanDisk Sansa Clip MP3 Player
Installation
Make sure hold/lock is not engaged.
Try another USB port.
If that fails:
-Tha Mp3 Doctor
Aug 28, 2008 | SanDisk Sansa Clip MP3 Player
Sansa c200
-Tha Mp3 Doctor
Sep 05, 2007 | SanDisk Sansa e250 MP3 Player
Stuck in refresh database mode with battery sign changing
-Tha Mp3 Doctor
Aug 31, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
121 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
