Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
How to adjust valves on ohv 18.5 briggs and stratton engine
SOURCE: Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
Posted on May 15, 2009
mowerman1857
  • 389 Answers
SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Posted on Sep 14, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
Dirt Dobber
  • 253 Answers
SOURCE: My Briggs and Stratton 24hp twin OHV engine
Gotta find it
Posted on Aug 13, 2010
SOURCE: briggs & Stratton 18 hp v-twin engine surges
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Posted on Nov 06, 2010
I have 18 h,p briggs and stratton very hard to crank
First check state of the battery under a load must have 12.5 or greater if battery is good check the valve setting the can cause an engine to be hard to start the valves should be approx 6mm
Jun 19, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How do I adjust the valves on a Briggs and Stratton Intek V Twin
Remove the valve covers look up your valve clearance specs turn the engine by hand until the piston is at top dead center then go 1/4 turn past that and then put a feeler gage for the valve clearance you need for that valve and snug up the adjustment nut. Check your oil when your done some oil will spill out when opening the valve cover.
Apr 17, 2013 | Briggs & Stratton Briggs Stratton Intek V...
18 hp Briggs blowing oil into the air filter
Sounds like your valves are sticking, possibly bent w/piston damage.
Dec 14, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
How to adjust the valves on b/s 18hp model 422707
Though the valves are adjustable, in a grinding cutting kind of way- they require the valve be removed from the block to do so. So no actual adjuster. The good news is, this "L head" engine doesn't have the same issues as the OHV family and rarely ever need valve service at all. Are you having difficulty
Technical Support
' Hotmail Support
Sep 13, 2012 | Briggs & Stratton Briggs Stratton Intek V...
18 hp vanguard 165lbs and 180 lbs compression have to hand turn engine past compression or starter wont turn engine over
if its hard to get the engine to turn past the compression release then pull your valve coversand try setting your valve lash
.006 on intake
.008 on exhaust
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
472 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
