Question about Garden
FLOODING CARBURETTOR ON MOUNTFIELD T35H MOWER OK WHEN USING BUT FLOODS WHEN STATIONARY hOW DO YOU CHECK FLOAT
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 12 Answers
First of all i hope u have a gas shutoff to the carb from the tank. If that float needle valve is not closing, the gas can make it all the way to the crankcase through the valve ports and get to the engine oil. Shut off the gss supply to the carb. or if no shutoff is on the machine, undue a line and plug it with something. U may be able to drop the carb. bulb off (bottom of carb.) by not removing the carb. from the engine.
If so, take the (usually four screws) out on the top of the carb. that looks like they hold the bulb on. The bottom should drop off and the float will be exposed. Be careful with the gasket between the two pcs.
Now check your float, that's all u ask for.
ballping
Posted on Jul 23, 2010
My 1977pe250 Suzuki won't start and is flooding is it the float or what
Could well be. Take the carburettor off and remove the float bowl in the bottom Carefully remove the float by sliding the fixing pin out. Check the fuel inlet jet for particles. Reassemble. Take your plug out, check the gap, and warm it up with a gas torch to clean it of petrol and oil. Brush with a wire brush. Screw it back in warm and start the engine with no choke.
http://images.cmsnl.com/img/partslists/suzuki-pe250-1977-1979-usa-carburetor-pe250n_bigsuusa90687_092c.gif
May 30, 2016 | Suzuki Motorcycles
Gas pours out of carb and muffler
float could be ok but the needle and seat or bad replace them
Aug 16, 2014 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
How to fix carburator flooding for craftsman model #917.270811
Sounds like your float valve in the bowl on the carb is sticking from dirt buildup in the open position or the float is bad sometimes the float develops small rust holes from the newer ethenol gas..allowing gas to enter the float ring and causing the ring to stay in the open position and flooding especialy when not running..if your mower had a manual shutoff make sure you shut it off EVERY TIME YOU SHUT DOWN if not put one on this will stop the flooding when not running..good luck..
Jun 25, 2014 | Craftsman Garden
I have a John Deere la105 it floods out cleaned carb put a kit and New float still floods
Replace the needle and seat and ensure the seat is tight check float height and small spring is attached to the needle.
Jun 09, 2013 | Garden
Small tube in carb floods engine (fuel keeps leaking out)
The float in the bottom of the carburettor is stuck. The primer feel different because the float bowl in the bottom of the carb never seals. Try tapping it gently with the broom handle again, just a sharp tap. If that doesn't work, you need to remove the carb and remove the float bowl on the bottom.
Jun 22, 2017 | Mtd Garden
Carburettor flooding with fuel
Remove the carb float bowl, remove the pin that retains the float and remove, the inlet needle will now come out, clean the tip, or replace the needle, clean away ant dirt in the needle seat and bowl.
Jun 09, 2012 | Briggs & Stratton Garden
When turn on petrol and kick bike, petrol is running out of overflow pipe on carb and bike wont start, and bike sounds flooded.
You have a sticking float in the carburator, due to old gas, or dirt. The float moves a needle that turns on and off the flow of fuel into the carb bowl.
Mar 23, 2011 | 2003 Suzuki RM 125
Have been having issues starting bike. Engine seems to be flooding for no apparent reason. e.g., this has happened multiple times.Started it today ( idling little low round 0.5k revs), let it run for 5...
A flooding problem is usually due to a problem with the foat and the needle/seat in the carburettor. This could be sticking open and allowing the engine to flood. Also, alowing an air cooled engine to run stationary for extended periods builds up considerable localised heat and this could be causing fuel to percolate and flood the engine. Back fire could be coming from a sticking valve - from the heat and a carbon build-up?
But first check the floats and needle and seats in the carb an shut off the fuel tap after shutting down the macnine.
Jan 16, 2011 | Honda CBR 250 RR Motorcycles
Flooding carburettor/
Check your "Float" & "Float Valve" in the Bowl of carburettor. Check mixture Make sure the valve is seating and the float is at correct height, & mixture is correct air/fuel ratio mix. .
Mar 08, 2010 | Garden
The float needle is probably stuck. Lightly tap on the carb bowl with a screwdriver handle or something similar. It might get the needle unstuck. If that doesn't work you will have to remove the bowl and clean the float needle and seat.
Hope this helps.
Bob
Oct 28, 2009 | 1990 kawasaki GPX 750 R
Garden Logo
196 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
