Question about HP Pavillion ZV6000 Notebook
Advent 7113 Hi, I have an Advent 7113 and recently the backlight is not working. I believe the fault lies with a part called inverter that need to be replaced. I am struggling to find the part number and secondaly where can I get but it from. You help will eb much appreciated. Regards Khas
4 Suggested Answers
  • 1019 Answers
SOURCE: Problems with advent 7113 backlight
i,d suggest trying the laptop on an external monitor firstly.
this will eliminate motherboard fault.
then if it displays fine on the external monitor.
possibility of Faulty Inverter Or CFL Tube.
Mike @ compurepair.
Posted on Jul 23, 2008
SOURCE: Advent 7113 doesn't detect mains
It is highly posible that the jack in your laptop where you plug the main dapter is making a false contcat due to a problem in the welding of its connectors to the main board or to corrosion. Check if the rentral plug is not loose or if the plugs seems to be loose when you plug it.
If it is so, you need some expert technician to solve the problem by re weilding it or replacing it.
Posted on Jan 27, 2009
  • 107 Answers
SOURCE: can't get a sound driver for my Advent 7113
try 2 download and install this audio driver for vista
http://www.softwarepatch.com/utilities/ac97-security-dl.html
Posted on Jan 28, 2009
suresh0954
  • 304 Answers
SOURCE: advent 7113 laptop very slow would like to return
After researching all the information online, I have put up the maximum possible detailed steps to help you out:
Your Advent computer uses the latest recovery system that doesn't require any CDs or DVDs to restore your PC to it's original factory condition.
1) Restart your Computer.
2) Press F10 repeatedly until the message "Starting System Recovery" is displayed.
3)
The recovery will load and display a menu of options:
(a)
Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
To access the recovery options below that erase all data from the computer, click the Advanced button.
(b)
System Recovery - No format: this will reinstall Windows®, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
(c)
System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
4)
Select the Non-destructive recovery option and press Next.
5)
You will be informed about System Restore in Windows, click Yes.
6)
The recovery will begin. Once this is complete click Restart.
Here are some additional information:
a) Press the ALT and D keys at the Windows style recovery menu options to access a command prompt. This will allow access to C: drive.
b) The command prompt will default to c:\minint\system32 where you can run a variety of tools including CHKDSK.EXE.
c)
For more information on these options, please read the Advent recovery trouble-shooter.
Advent recovery trouble-shooter:
If a user is experiencing recovery problems on an Advent PC, then try to follow these steps.
Note: These steps will remove all personal data and all applications installed after the PC was purchased. Where possible ensure that all data and personal files are backed up BEFORE trying these destructive diagnostic steps.
1)
Check the integrity of the recovery CD, or the update CD.
2)
It is possible to verify the integrity of the recovery CD, or the update CD from within the Recovery programme.
a)
Boot from the recovery C.
b)
At the ‘Press R to display system recovery options’, press ‘R’.
c)
Once in the System Recovery screen, press ALT + D to access the WinPE command prompt.
d)
Type in Xcopy D:\*.* /E /V C:\ and press Enter.
e)
D:\ is the CD ROM drive letter
C:\ is the HDD
/E copies everything
/V verifies the data with a CRC check
f) If there is an error with the CD, then you will get the message:
File creation error – Data error (cyclic redundancy check).
g) If there are no errors, then you will be left at a prompt again.
3)
If Windows® is accessible, then boot from the recovery CD.
4)
5)
Once in the System Recovery screen, press ALT + D to access the WinPE command prompt as below:
6)
Type COPYSI and hit Enter. This will unhide the user's smartimage (this may take a few minutes to complete).
7)
Return to Windows® & copy the contents of the C:\Update CD\ folder to CD (N.B. Do not copy the ‘Update CD’ folder itself). Ask the user to label this ‘UPDATE CD’.
8)
Start with the recovery CD ROM in the CD drive.
9)
At the ‘Press R to display system recovery options’, press CTRL + BACKSPACE to get the hidden menu as below:
10)
Choose option:4 (Clear the partition table of drive 0x80). Once you have selcted this, you will be returned to the Press 'R' screen.
11)
Choose option:5 (Erase the Master Boot Record of drive 0x80). Once you have selcted this, you will be returned to the Press 'R' screen.
12)
Choose option:7 (Create a primary partition on drive 0x80). Do not restart the machine during this process. Option 7 may sit for up to 10 minutes with a flashing cursor as it creates the partition. If the HDD LED is flashing, then you know that the process is proceeding.
13)
Once the HDD partition has been created you will be returned to the ‘Press R to display system recovery options’ screen. Press ‘R’.
14)
The recovery should go straight into a full destructive recovery, and will ask for the update CD which we have created.
Hope this Helps.
Please feel free to ask further questions.
Posted on Aug 15, 2010
Advent 7111 narrow screen
If the display isn't going full screen, on that 15.4 inch TFT LCD screen, the problem is the screen Inverter, or LCD screen itself.
90 PERCENT OF THE TIME the fault is the screen Inverter.
It isn't a simple screen resolution setting that needs to be changed.
http://www.laptoppowerjacks.co.uk/advent-inverter/advent-7111-7107-8315-lcd-screen-inverter-as023217127-iv09140t-lf.html
Primer:
An LCD screen does not produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
It needs an additional light source.
The additional light source is a Backlight.
A Backlight can be a CCFL, or a series of LED's.
The Advent 7111 Notebook PC uses One CCFL,
http://www.screencountry.com/index.php?section=products&model=7111&brand=Advent&size=
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick. Length is almost as long, as the LCD screen is in height. 2mm is close to 1/16th of an Inch )
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Primer over.
I don't have access to a Service Manual, for the Advent 7111 Notebook PC. I haven't had one come to my shop for repair.
I DO have years of experience at repairing laptops, and I see the Advent 7111 is just a basic laptop, as I HAVE repaired over the years.
If you wish, I can guide you step by step, in replacing the screen Inverter.
(MANY people go out, and buy an LCD screen, when the problem is a much less expensive screen Inverter. Afterwards they buy the screen Inverter. Too bad they didn't come here first)
Post back in a Comment.
Regards,
joecoolvette
[ The Advent 7111 Notebook PC is just a re-badged Quanta TW3M.
According to the source, you should see TW3M on the bottom of the laptop.
http://www.uktsupport.co.uk/advent/laptop/7111.htm
May 20, 2012 | Advent Computers & Internet
Screen on laptop advent 7102 very dull can hard use it hardly any brightness
The LCD screen for the Advent 7102 does not produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
An Inverter (Screen Inverter) converts electricity from the laptop, for the LCD screen, and the Backlight.
90 PERCENT OF THE TIME the fault is the Inverter.
The Inverter is a small circuit board located behind the Display Bezel, and under the LCD screen.
[ The Display Bezel is the thin plastic frame in front of the LCD screen. Resembles a picture frame ]
Example of a screen Inverter for an Advent 7102 Netbook PC,
http://www.laptoppowerjacks.co.uk/category-27/Acer12.html
Regards,
joecoolvette
Oct 17, 2011 | Advent Netbook
My screen is blank upon turning the laptop on I have to almost close it in order to be able to see anything on it.
If you can see a faint image on the screen, the fault is possibly with the screen inverter.(possibly the screen backlight)
Try testing the laptop on an external monitor, that way you eliminate any issues that may lie with the graphics chip.
After that, and if this works, you will need to have the screen and inverter checked by a qualified technician as it is likely the problem lies there. Ther might also be an issue with the VGA cable to the screen. I'd check that there are no trapped wires from the body of the laptop to the lid too, unlikely if it has not been disassembled, but worth checking
Dec 30, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
BLANK SCREEN MAYBE THE VGA CARD? pLEASE HELP
Hi first thing to do here is to see where the problem lies. use a vga / monitor lead from your laptop to an external monitor or lcd/plasma tv in pc mode and by pressing fn and your monitor switch key think its f5 you should be able to determine if your screen is at fault, a common problem is the screens inverter or backlight bulb, if you manage to get an image on your external source then you its sure to be screen related wether it be the inverter/backlight/or even your internal screen lead this process can save money and time, you would then need to test the inverter to see if its this, the inverter is normally the cheaper option as the backlight can be a long tricky process.
I hope this has helped please rate :)
Feb 23, 2010 | HP Compaq Presario CQ50-110US Laptop
Jan 12, 2009 | HP Pavilion dv6000z Notebook
Mike @ compurepair.
Jul 22, 2008 | Computers & Internet
HP Pavillion ZV6000 Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
