Question about Behringer EUROPOWER EP2500 Amplifier
My behringer europower EP2500 poweramp has a bad hiss on channel 2 What could this be?
  • 17,130 Answers
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Posted on Jul 18, 2010
My EP2500 keeps on blowing a fuse on the right channel and I opened it and realised that the two horizontal caps are a bit bigger.
They wouldn't blow the fuse. You are looking at the main devices that power the channel. If you put an ohmmeter on their terminals (assuming they are transistors) then it will show like you have touched the two test probes together. If it does replace the part(s).
Oct 24, 2013 | Behringer EUROPOWER EP2500 Amplifier
What number should i set on each channel running behringer vp1220 speakers
Go to owners manual in the specifications page.
Will show the impedance, you should mach the impedance output with the speakers,2,4, 8 Homs impedance and how many watts RMS or peak.
Oct 11, 2012 | Behringer EUROPOWER EP2500 Amplifier
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
I have EP2500 amp i want to use it to push 6 tops, what should i switch it to? one channel must push 3 tops and the other as well pushing 3 tops.
OK, you can use ep2500 amp to power 3 tops each,But the only challenge is that you are about to over load your amplifier. might get hot too fast .
You can use a cooling system to make it not too hot..It also depends on how the event your using it for...Using 3 EP2500 amplifier to drive three 6 top, using two top for each amplifier. Just a suggestion.
Using 2 amplifier, you will need to drive on one channel to drive 2 tops, and 1 top for the other channel.
That will do. But make sure you turn on the volume of the amplifier to the max volume ,so that it will be able to work properly for your tops...
Mar 31, 2011 | Behringer EUROPOWER EP2500 Amplifier
Clipping the channels
The manual discusses the Clip Inidicator and how to deal with clipping.
Clipping in this amp isprimarily a function of the input signal being distorted so the input level is recommended to be lowered. Beyond that the cause of input distortion would have to be addressed in the device producing it.
http://www.retrevo.com/support/Behringer-EP2500-Amps-manual/id/23281ci655/t/2/
Dec 30, 2010 | Behringer EUROPOWER EP2500 Amplifier
What wattage speakers do I use with europower ep2500
Wow thats a serious system you have there.God help the neighbours!Anyway here is an example.you need a pretty serious speaker.At 8ohms,you would need something like a 8ohm 450watt speaker system.Anything smaller will stress your amp if you turn it up.The amp would kill smaller speakers or the amp internals(channels)at higher volume.It would be like hooking up a garden hose to a fire hydrant.Something would have to give.hope this helps and happy listening
Oct 18, 2010 | Behringer EUROPOWER EP2500 Amplifier
Red light on permanently one 1 channel, that channel just buzzes
on beringer europower ep2500 if both clips lights is on chane d9 d10 d11 d12 and the two 220uf caps for the +15 and -15 voltage supply for the op-amps it a common fault alvan dawkins
Oct 24, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 amplifier channel crackling noise
Got asilimar problemwit a behringer europower pmh 3000.
my
The Right channel began to crack up and drizzle now it seems completely dead.
Changed the cables both of input and seapkers , still the problem stays the same. Any suggestion before brigning for a month at the repair shop? And get out with a 200-400$ bill ?
Apr 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
481 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
