Question about Hoover Vacuums
Have a hoover steam vac that wont **** up the water brushes spin
  • FRANCES LESCOVICH Jul 18, 2010
    DID NOT SOLVE PROBLEM WITH A STOCK ANSWER OF THINGS I ALREADY DID.STILL THE HOOVER STEAM VAC WILL NOT DRAW UP ANY SOLUTIONS
  • 146 Answers
Look at the bottom, where the water comes out and comes back in? Is it filled with hair/dirt? It might need to be cleaned out where the water sucks up in at. Otherwise I would go to Hoover.com website for f.a.q.s or technical support.
else
If you find that your cleaning solution will not dispense, check that the tank is securely in the locked position. There is also a chance that the solution tank is empty, in which case fill it with cleaning fluid. Ensure that the recovery tank lid is firmly in place.
or
Prime the pump. Priming means to remove air from the system so that the cleaning fluid can flow to the tool. You "prime the pump" by attaching the tool to the hose and turning the carpet clearer to ON. Then put the tool on a hard surface or against your hand to block the suction. It may take up to 15 seconds to remove all the air. Once this is done, squeeze the trigger on the machine and begin to clean.
Thank You.
Posted on Jul 18, 2010
    DID ALL THOSE THINGS STILL WILL NOT **** UP SOLUTION
Hoover spin brush steam vac F5906-900
Try giving it a good clean-out
This is the manual for it
Feb 04, 2014 | Hoover SteamVac F5914-900 SpinScrub...
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
My hoover spin brush steam vac brushes wont spin
Unplug vac turn it over and check for belts that drive the brushes
They are located at the very end of the brush They are probably missing
or they snapped and sitting in the housing somewhere. If you ar mechanically inclined not very difficult to replace. While you are at it clean all the hair and fibers that usually accumulate around the brush bushings
That is usually the culprit that wears down the belts
have fun
Feb 06, 2012 | Hoover Vacuums
New Hoover Steam Vac's brushes do not spin
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Turbine Brush Gear Part # 43191008
F5914 Parts Link
http://www.usavacuum.com/Hoover-F5903-F5904-F5905-F5910-F5912-F5914-F5915-s/138.htm
Feb 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I own a hoover steam vac model f5915-900 and i currently have two problems. 1. the brushes are spinning at a much slower speed. 2. the steam vac is not picking up the water it leaves on the carpet....
the reason the brushes are not spinning is because the belt is slipping, the belt is the bad that connects to the brush to a shaft that makes it spin. Next problam is it is probobly clogged. so water is not going through all the way
Sep 08, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
140 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
