Question about Car Audio & Video
I plug in rockwood detanator VII and it goes to protections mode
I wired up my rockwood detanator VII and it goes straight to protection mode i dont know what could it be i never used it until now and i had it since 98
  • 323 Answers
Generally if an amp goes straight into protection, the amp is not grounded well enough. Either you should find a new location to ground the amp to or unhook the power wire from the battery, remove the ground wire from the chassis of your vehicle. Strip the paint from the chassis, since it doesn't conduct electricity, and remove any corrosion or copper shielding from the ground connector. reground to a solid metal location Can be grounded to the brace behind the back seat or to the seat belt bolt for best results.
An amp draws a lot of power, there it needs to be grounded well.
Hook back up your power wire to the battery and see if your issue is resolved.
Posted on Jul 28, 2010
Protect mode on my sony lbt xb500
When ANY amplified product goes straight to protect mode there are either a wire touching or the copper coil in one or more of the speakers is burnt od over extended its limit
Nov 13, 2011 | Audio Players & Recorders
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
New System Just out of the Box and the very first time I turn it on it checks for all the DVD's and then "Protector Puch power" Message. I check all the wires and Not sure how to do test tone as every time...
Straight to power protect mode indicates crossed wires somewhere or otherwise miswired system. Disconnect all the speakers and try to power on to see if it still goes into protect mode.
If it does, read the manual for troubleshooting tips, or return the unit as defective.
If it does not then replace the speakers one by one until it returns. Check the wires going into that speaker, that speaker may be defective or you may be wiring it wrong.
Aug 14, 2009 | Sony DAV-HDX500 System
My ampli start bot only in protection mode
amp could be blown, i.e. speaker wires crossed up, too much power..............
Jun 07, 2009 | Rockwood X-Plore AMP-4010 Car Audio...
I really need ur hlp badley
If the protection light is lit, the amplifier probably has shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect mode - Troubleshooting
Nov 05, 2008 | Car Audio & Video
Car audio amp in protection mode
If you power up the amp with the RCAs plugged in, does it go into protection mode.
If you power up the amp with the RCAs plugged in, does the woofer pop?
Oct 26, 2008 | Pyle PLAD413 Car Audio Amplifier
Amp volume problem
Sounds like you have a bad or dirty gain potentiometer. Try turning the gain up and down with the volume at a moderate level. If u hear static, it is possible the potentiometer is bad or dirty. Replace with one of the same value and see if that solves your problem.
Jul 15, 2008 | Rockwood Car Audio & Video
My amp turns on and off
Sounds like there could be a short somewhere. Check to make sure that there aren't any (exposed/bare) wires touching each other or if there is a bare spot of wire touching something metal. Check both ends of all the wires. A speaker wire may have come lose and is shorting out against the frame or some other place. Usually if it goes straight into protection mode or you're popping fuses you have a short somewhere. I assume the capacitor you installed is somewhere on the power line, which would be for helping with
noise. You can also try disconnecting your amp from your stereo and see what happens but leave the speakers connected, you don't want to run the amp with out a load on it (the speakers). If your amp doesn't go into protection mode when the stereo is disconnected, then you have a problem with the stereo and not the amp, assuming you already checked for any possible shorts first.
Jun 15, 2008 | Pyramid PB1236GX Car Audio Amplifier
Crunch GP 3000 D Pro
It's very likely that the output transistors have failed in the amp. They will need to be replaced.
Jun 14, 2008 | Crunch Drive V-600 Car Audio Amplifier
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Car Audio & Video Logo
152 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
