Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
Where is oil drain plug on toro 22'' mower- tecumseh engine
  • 718 Answers
IF you do not see the drain plug o the side of your engine, than most likely it is located on the bottom of the engine you will most likely have to remove the guard that covers the belt if you have self propelled lawn mower and the plug should be under the guard. Good Luck
Posted on Jul 18, 2010
My 22 Toro recycler mower how do I drain the oil and how much is required to be added?
Look at the bottom of the engine or under the deck for a bolt to remove that will drain the oil..
Nov 07, 2016 | Toro Garden
Toro 22" recycler lawn mower, Briggs & Stratton engine. Engine low on oil, would not start after a few pulls. 20 oz oil added, mower started after a few pulls. Finishing the lawn when a white puff of...
Hi michael, You have most certainly put in too much oil. Try draining a bit off and then clean the spark plug with some paper towel. Leave the mower level for a few hours and then try it again.
Sep 22, 2013 | Toro Garden
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
Where is my drain plug on my toro lawnmower
there is one on the bottom of the engine i just run mine out of gas the turn it on it's side and drain it from the dip stick tube
Apr 12, 2012 | Toro Power Lawn Mower
Where is the oil plug underneath the mower?
Depending on what engine is on your Toro lawnmower, there may not be a oil plug under the mower deck. A briggs and stratton engine will have one, but if the unit has self propel then you will have to move the guard over the self propel cable. This is a 1/2 in bolt, you will also have to loosen the other bolt to swing the guard around.
On a Kawasaki or Honda, and even if you have a Tecumseh engine then just start the mower up for a few minutes and let the engine oil get warm, then shut the engine off and then lay the mower on the side that has the oil filler cap and put your drain pan under the oil filler cap. You can then drain the oil out of the oil filler tube. You can also do this with the briggs and stratton engine. I find this to be a very convenient way to change the oil.
Then put fresh oil back in the unit. I always suggest to put the engine manufacturer's oil back in the unit, or if that is not available then use another oil from another engine manufacturer. IF you use automotive oil, the oil will break down faster since the heat level for the engine on car is less than that of the engine on your lawnmower. The engine has a water cooled design, that keeps the engine temperature from raising over about 250 degrees F. The engine temp on your lawnmower can get as hot as 400 degrees F in the summer heat and being run for 30 minutes or longer.
A longer answer than you had hoped but I hope the information keeps your lawnmower running well for many summers to come. :)
Apr 04, 2011 | Toro Power Lawn Mower
Replacing a tecumseh carburetor on a toro
PartsTreeRepairClinic may have a video
Jan 30, 2018 | Toro Garden
How do you drain the oil on a 4.5hp MTD tecumseh engine, their is no oil drain plug.
unplug the spark plug and tip the mower towards the side with the oil filler tube. Place a bowl on the ground to catch the oil. Thats it!
Jun 29, 2010 | Mtd 22" Yard Machine Push Mower
22 in persoal pace 195 cc Tecumseh oil leaks onto
There is a crankcase vent on top that may be cracked or out of place causing the oil to leak or the upper crankshaft seal may be leaking.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
Where the heck is the drain plug?! Yerf Dog Fun Cart 3203
The drain plug is located under the mower where the blade shaft comes out it may be covered in caked grass clippings scrape them of with a screwdriver or putty knife to reveal the square oil plug.
Aug 07, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
267 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
