Built in wifi cards are very limited in range, get an external pc card
then you can get an antenna to connect to that if needed.
I use both and find the external card is best in reception.
you can connect an antenna to the internal card but you will have to leave the access panel open or make a hole in it.
USB wifi adapter defaults to its best setting so there is nothing you can do to make it pick up signals better.
You might be able to increase your routers broadcast range if the router belongs to you.
If you are using a laptop in a public place (like an coffee shop or an airport or something) the best thing you can do is move around and get closer to the router, they have decent range so you shouldn't have to move very far.
The instruction manual should have tips on boosting range.
http://www.buzzle.com/articles/how-to-boost-a-wifi-signal.html
hope this helps
