Question about Digital Audio Televison & Video
How do i connect a audio pin from the camcorder to the amplifier
    Scholar:
  • 41 Answers
If the Camcorder has the A/V OUT, you can connect the A/V OUT of the Camcorder to the Audio IN on the Amplifier. You can use RCA Cable to connect like this way.
If the Camcorder has the Headphone OUT jack, then you can connect it to the Stereo mini IN on the Amplifier. This should work.
Some Camcorder have the HDMI OUT jack. You can connect the Camcorder to HDMI IN on the Amplifier(if it has one).
Posted on Jul 18, 2010
Is audio output (from main ic) is imputed in utc2003 audio amplifier ic?
Is the UTC2003 IC your main IC?
You can't find inputs or output of this IC?
This IC is power Operational Amplifier simply. It has TWO inputs noninverted = pin 1 and inverted = pin 2 and ONE output = pin 4. Pin 3 is ground and pin 5 is supply voltage. It's simple as the rake! What is your problem? Sorry for my rusty English...
Feb 03, 2015 | Audio Players & Recorders
Tv loses sound after around 45minutes of being swiched on
there may be problem in your amplifier or the mute signal or the input signal from processor or speakers, First you have to check the audio output from the processor by using another external amplifier... connect it to the correct audio out pin of processor( these are R,L audio written in pcb near the processor lead that carry) if there is sound moreover than 45 minute....... replace the external amplifier and connect it to its own amplifier.... disconnect the own cabin speakers and connect another sp. and check... if there is sound break after45 minute.... replace the amplifier ic(may beTDA7297) if there is still have the problem, check the amplifier circuite suitable for your ic and dissconnect the mute connection from processor and make a connection to the +ve or ground follows as the circuit(means give external mute signal to amplifier dont from processor)......
Nov 09, 2013 | Televison & Video
How to connect tv to amplifier
Look for audio/video out pins on the TV. The yellow is for video. The red and white are left and right audio channels. Connect an RC cable to these two (Red and White) and connect it to your amplifier. Never connect your RC cable to Video out or in (Yellow) even by mistake. This might damage your TV.
Jul 11, 2012 | Televison & Video
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
How do i connect the souncard to an amplifier for speakers
To conect a sound card to an amplifier is easy onect the pin to the audio out put of the sound cand and to the audio in in the amplifier and make the selection mode as aux then the sound card will be amplified with amplifier also increse the volume in the sound card to approximate level
Apr 05, 2011 | Numark DJ/iO Sound Card
How do I connect a camera to my pavilion n5430?
Follow these steps :
Identify the ports you have on your computer and video camera. Typically there will be a small door or flap at the rear or near the bottom that covers the ports. You computer may have ports in the front as well as the rear. You video camera may have more than one of these ports and may not have all of them.
Find the i.LINK port. i.LINK is
version of IEEE-1394 standard (aka) Firewire. It is commonly found on DV (Digital Video) varieties of camcorders. You may find the smaller 4 pin connector on your camera if it is a compact video camera. Typically the larger 6 pin variety is found on computers and larger camcorders. i.LINK transfers both video and audio. For more information click on "How i.LINK Works" in the Resources section.
Find the USB port. USB (Universal Serial Bus) is another connector like i.LINK for transferring digital video and audio. Typically a mini USB connector such as the "Mini-A" will be found on your camcorder than large flat "Type A" connector typically found on computers.
Locate the S-Video jack. The S-Video jack is a round 4 pin analog connector. S-Video is for only video transmission. You will need to connect the red and white audio RCA jacks or use a phono port to transfer the audio to your computer.
5
Find RCA Audio/Video Jacks. These round single pin ports usually are found in a set of three of different colors. Yellow is video, red is for right audio, and white is for left audio. On some Handycam's, there may be a mini-plug that is an all in one Audio/Video jack that you plug in a special cable (as seen in the photo) that connects your camera to standard yellow, red, and white RCA jacks on your computer.
6
Choose a matching pair of ports you have on both your computer and your camcorder.
7
Turn both your computer and camcorder off.
8
Connect your computer and camcorder with the appropriate cable. Turn on both your camcorder and your computer.
Nov 20, 2010 | Computers & Internet
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Need adaptor for older Sony analog camcorder - CCD-TRV70 DC 6V
You need to get a Digital to Analogue converter such as the Canopus ADVC110 A/D Converter. (circa $225). There may be cheaper alternatives. (you might also be able to use a digital camcorder that has a built in Analogue to digital converter):
 Canopus 77010150100 ADVC110 Converter
The Canopus comes with a 6-pin firewire cable. Since your Dell Studio has a 4 pin Firewire (actually called iLink) you will also need a 6-pin to 4-pin cable or an adapter:
 Firewire 6-PIN To 4-PIN Cable
 Cables To Go - 27028 - Firewire 6-Pin Female 4-Pin Male Adapter
You hook your Sony up to the A/D converter with audio and video cables (usually supplied with your camcorder) and hook the converter to you Dell with a firewire cable. Then you capture the video using some video capture software. I don't know what comes with windows these days.
Jan 22, 2009 | Sony Handycam CCD-TRV308 Camcorder
Replacing a Blaupunkt Reno with Florida
Hiii...
This is a PIC mybe can be help you...
Thank's
Jan 27, 2008 | Blaupunkt PA4100 Car Audio Amplifier
Audio volume
Unfortunately, connecting an external mic is not an option that was engineered into this model camcorder. Likewise the speaker and small amplifier for audio playback is simply what it is. You should be able to adequately hear normally recorded levels. If not, maybe there is a problem with the internal condensor mics or the playback speaker. If you are unable to obtain a resonable level using A/V cables to a TV, then something could be wrong. I have not seen problems with this model regarding sound, but anything can happen. Good luck, ms
Aug 30, 2007 | JVC Cybercam GR-DVL520A Mini DV Digital...
Televison & Video Logo
43 people viewed this question
Top Digital Audio Televison & Video Experts
Are you a Digital Audio Televison and Video Expert? Answer questions, earn points and help others
