Question about Toshiba REGZA 47HL167 TV
My toshiba LCD tv model# 47HL167 turns on but I
As I desribed above my tv will turn on but I get no picture! This just suddenly happend as I was watching tv I changed channels then the screen went blank. I have tried unplugging the tv & waiting and still no picture.I have noticed that when you push the power button that a orange lite flashes eight times before a green lite turns on & I'm not sure if that is normal but It seems to be longer than it should be. Please help!!!! And thank you!!!
  • 4,889 Answers
Do you still have sound? Do you atleast have a dull glow on the screen? Sounds to me like its a back-light inverter failure- the only thing that can cause the screen to die so suddenly!
Posted on Jul 19, 2010
  • 10,515 Answers
This is a hardware failure.These sets are more prone to power failures as compared to other models.The most common problem i have seen is bulged/ swelled / leaked caps.
If you have electronics repair experience, know schematics, could use multimeter and soldering iron and keep all precautions, i would be more than happy to assist you.I would be able to tell you few pointers that would help you to repair this.
Unfortunately, there is no reset button.It has to be repaired.
Note - I am assuming that there is ' No Picture , No Sound situation ' with 8 blinks.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 18, 2010
Connect pc laptop
This TV has a PC interface VGA (HD-15) , so all you need is get a VGA to VGA cable to plug between the VGA output on the PC and TV.
On the PC select the display as external monitor.
On the TV pick the PC input as required input, not the TV tuner.
Here is the manual.
LCD TV 47HL167 Support Toshiba
Jan 05, 2014 | Toshiba REGZA 47HL167 TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
No display on my screen when i try to turn it on and a bad smell comes
dear user,
dont use your lcd until its fault get fixed. lcd capacitor is leaking oil.kindly change the capacitor at your earliest
Feb 11, 2011 | Toshiba REGZA 47HL167 TV
No backlights
The T-Con board is dead.This board sit right in the middle in the bottom of the LCD screen panel.This board is dead,require replacement.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con board for the replacement.
May 24, 2010 | Toshiba REGZA 47HL167 TV
Tv wont show picture but can hear volume
Ur LCD inverter board is dead.Replaced this board will get ur picture back.It a long board uaslly.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board.
Feb 17, 2010 | Toshiba REGZA 47HL167 TV
47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
Dec 15, 2009 | Toshiba REGZA 47HL167 TV
Blurry(ish) picture
nead new picture cartrage
Nov 19, 2009 | Toshiba REGZA 47HL167 TV
47" Toshiba Regza 47HL167 - No picture but with sound
My guess would be to suspect the inverter. but from what i can tell that model had two possile inverter types used during production.
toshiba P/N 75008432 Rev C3
AND
75008433 V470H1-L
Oct 06, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA 47HL167 TV Logo
133 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
