Question about Refrigerators
GE Profile Anatica stopped cooling. The lights and temperature indicators are working. I tried to adjust the settings but it will not hold. the temperature inside the refrigerator says 77 degress. Is there a reset button or switch that needs to be engaged?
    President:
  • 1,197 Answers
Do you hear a fan running in the freezer? if you hear the fan running
The fan motor running tells me the problem has to be in the motherboard on the rear of the machine, this is part number WR55X10942, You can order the parts you need from the following places, http://www.apwagner.com/, http://www.repairclinic.com/, or http://www.partstore.com/, all of these places offer easy returns and reasonable prices for their items.
if your fan is not running please get back to us for further analysis.
Posted on Jul 18, 2010
How do you work temp control on GE Profile top freezer
The ACTUAL TEMP light will come on and the display will show the actual temperature. To change the temperature, tap either the REFRIGERATOR or FREEZER pad until the desired temperature is displayed. To turn OFF cooling system, access SETTINGS from the HOME screen. Page over and tap COOLING SYSTEM ON.
Sep 22, 2017 | GE Refrigerators
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
    most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
    Jul 11, 2011 | GE Refrigerators
    Fridge side working but only cooling to 50 degrees
    My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
    Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
    My 7 year old GE Profile Side by Side will not get
    Self Diagnostics
    To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
    can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
    illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
    4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
    freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
    For temperature control panels with single-digit displays, the COLDER temperature adjustment button
    will increment the numbers up and the WARMER temperature adjustment button will increment the
    numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
    freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
    the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
    Press the HOLD button for 3 seconds to begin the test.
    For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
    increment the numbers down and the WARMER temperature adjustment button will increment the
    numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
    freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
    code. Press any button other than a temperature adjust button to begin the test.
    When testing has been completed, do one of the following things:
    • Enter code 1 5 to completely reset the system.
    • Enter code 1 6 to exit diagnostic mode. GSS manual
    May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    I bought an oven thermometer and it indicates that the oven temperature is approximately 100 degrees lower than the temperature set on the oven. Is there an adjustment to make so the set temperature is...
    It sounds as if an element in the oven is not working do check again that the oven thermometer is on same scale as the oven settings farenheit or centigrade.Most likely it is an element fault.
    Hope I helped.
    May 07, 2010 | GE Profile JT915 Electric Single Oven
    Express Thaw comes on when refrigerator door is closed
    We have a GE Profile side-by-side refrigerator which we purchased in 2002, Model PSS25NGNACC. Today we had a repairman come to investigate why the Express Thaw 3lb. light was on and could not be shut off. If shut off, it came on again when the door was closed and reopened. The repairman called GE and learned that this light was an air filter change indicator which turns on at some interval (2 years, they said, although we don't remember ever seeing this before). The air filter involved is for the interior of the fridge and is not critical. GE said that newer master control boards have this function disabled, since people rarely changed the filter and GE no longer makes them. I have read our user manual cover to cover and find nothing on this filter. I guess we just have to pay the $70 dollars to have someone come and call GE to figure it out. But, enough of that. To reset the indicator, simultaneously press the following keys on the touchpad and hold for 5 seconds until it beeps:
    Adjust Freezer Temp (Warmer)
    Express Thaw
    Adjust Refrigerator Temp (Colder)
    Lights and functions should return to normal.
    Feb 11, 2010 | GE Refrigerators
    GE Profile cook top - four years old
    unplug unit allow to dry ..12 to 24 hours,,or cut breaker to stove,,,try again..if still lite..you ground out,,you have to take a look at light circuit for ground short
    Dec 24, 2008 | GE 30 in. JP340 Electric Cooktop
    GE Profile does not run.
    Just to be sure... check your owners manual to see if this unit has a "showroom switch". It's a little switch that turns off the compressor, etc. but lets everything else light up so the sales persono on the showroom floor can show it off. Some customers have hit the switch to "on" during cleaning by accident.
    Sep 29, 2006 | GE Profile PSS26NGS Side by Side...
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
