Question about KitchenAid KPTT780ER 2-Slice Toaster
Toaster not heating up, but blue light comes on
The blue light come son when you turn the knob, but there is no warm up noise and the element to not heat up
I have the same problem with mine. Have you managed to fix yours?
Posted on Aug 22, 2010
Space heater stopped working
First, check the warranty to see if it still in effect. I suspect a bad contact, broken control or problem with the heater element connections. If there is no physical damage from being dropped, tripped over, etc., then something like this would be a manufacturing defect (premature failure). If it's out of warranty, and you know how to use a multimeter, you could unplug the heater and start checking the continuity of the parts and wiring inside.
Jan 07, 2014 | Holmes Products Heating & Cooling
Unit power on light is illuminated but no heat from heating element,
The thermostat may have failed. It could be adjustable mechanically but not electrically.
Nov 06, 2013 | Anvil SAA8003 Stainless Steel 3000 Watts...
Kitchen Aid Artisan 2 slice toaster, model 5KTT780 Blue light comes on but not as bright as usual, elements don't heat up.
Try pacific8's answer to this problem with another KitchenAid toaster, especially the comment on that answer by pacifics pam, all found here: http://www.fixya.com/support/t9655297-toast_will_not_stay_down_in_toaster_when
Jun 08, 2011 | KitchenAid KTT780 2Slice Toaster
The coils (heating) do not appear to be working Tost comes out warm but not brown!!!
Inside your toaster there are four heating element plates two in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Mar 27, 2010 | Dualit 20247 2-Slice Toaster
Back to Basics TEM-500 toaster no longer heats up
We have the same problem after only about 20 uses. The customer service number is 1-800-688-1989...we may be able to get it replaced. If they aren't willing to do anything, I'm thinking of filing a complaint with our state Attorney General because there are SO MANY complaints of the SAME, idential problem from thousands of consumers!!!!
Jan 02, 2010 | Back to Basics TEM-500 Egg & Muffin...
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I bought a kenmore toaster oven. There were no instructions.
This controls the heating elements in the oven Briol// Bake// and Toast
Dec 16, 2008 | Toaster Ovens
Heating elements turn off while timer is still running
ask the service center at;
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700---Steve Karow
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Nov 20, 2008 | Dualit Vario 3 Slices Toaster
Dualit 4-slice toaster (84US) warms only slightly
please check and make sure the red button in front is pressed to the right so that all 4 slots will heat up.
if it is to the left, only the left 2 will heat up.
if you need additional help contact the service center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Nov 01, 2008 | Kitchen Appliances - Others
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
KitchenAid KPTT780ER 2-Slice Toaster Logo
429 people viewed this question
Top KitchenAid Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Appliances - Other Expert? Answer questions, earn points and help others
