HOW DO I HOOKUP THE DVDRECORDER TO MY ALREADY CONNECTED DVD/VCR,TV,SATELITE BOX
  • 975 Answers
I suggest an AUDIO/VIDEO SELECTOR BOX since your going to be using your DVD RECORDER to record from these sources. hope it helps.
Posted on Apr 21, 2008
I need help connecting tv to DVD player VCR and satellite box
Connect as following
1. Set top box - RF cable from STB to antenna socket on TV.
2. DVD player output to Video1 on TV
3. VCR output to Video2 on TV.
May be you can route VCR through the DVD player or viceversa. That you can see and try on ground.
Sep 28, 2010 | Haier TN201AUV 20" TV
Wiring diagram,connecting DVD & VCR to a television
Need to select proper input on the TV when playing DVDs. For VCR, select channel 3 or 4.
For cable TV or satellite TV , change channels on the proprietary box and record channel 3 or 4 on VCR. You can also hookup RCA cables (3) from cable box etc. to VCR. Select LINE input on VCR if connecting RCA cables.
Aug 23, 2010 | Televison & Video
Vcr
do you have a cable box/satelite/directtv? yes..okay box out to vcr in....vcr out to tv...(vcr must be set to ch 3 at all time)....no box at all, antenna should be connected to vcr/tv
Jun 19, 2010 | Memorex MVD4540 DVD Player/VCR
I have a dvd/vcr that does not have a coaxial cable hookup on back of vcr. I need to have my satellite hooked up
If your VCR does not have the coax connection then you should either have RCA inputs and outputs or the BNC type of connections. If you have the RCA style then you can connect your sattelite receiver using them. If you have the BNC type then you may have to contact the manufacturer to see if there are converters available to switch your RCA ends to BNC. You will also have to find out if the BNC connections will even work with the outputs from the satellite receiver.
Feb 02, 2010 | Televison & Video
How to hookup vcr to TV to tape from satelitte
Go from the output of the satelite to the vcr/dvd input and from the dvd/vcr output to plasma set.
Mar 06, 2009 | Panasonic Televison & Video
How do I hook up my Dish Satelite to it?
should go from your satellite to dish box might say sat on bck of box then the next [connection think says tv that should go to tv itsself or dvd vcr whatever ur hooking up to it then from that point hook it to ur tv
Oct 23, 2008 | JVC AV-56WP74 56" Rear Projection...
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd/vcr with ** hookup for cable tv
Just hook your antenna or whatever wire you have currently connected to the TV to the input on the new recorder, and you'll be to record anything you can watch now.
Mar 10, 2008 | Memorex MVD4540 DVD Player/VCR
Dvd/vcr without cable hook-up
If ** cable TV hookups exists, then the only inputs you can use are the line-in along with audio left/right. You've probably got a slew of output connections. Your unit does **t contain a tuner (which would allow you to use a cable input). You need to have a cable box or other device (vcr/tv) that has outputs compatible with the input of your dvd/vcr. A lot of dvd/vcrs are that way. It actually saves you some $$ since most cable boxes (especially HDTV compatible) already have the required outputs on them.
Mar 09, 2008 | Memorex MVD4543A
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
