FUBA digital satellite receiver ODE 582/592: I think the memory of my receiver is full (3000 channels); when I do a new automatic scan, nothing changes. Any ideas? R. Bear
  • 1153 Answers
SOURCE: satellite receiver not respond
Search internet for JTagging sonicview receiver. You will need special equipment.
Posted on Sep 04, 2007
  • 1153 Answers
SOURCE: I can't turn on my satellite receiver
Is this a Pansat receiver? If so or not then you will have to find out about Jtagging your receiver. Maybe because bad script or just cloning you have to jtagg first then rescript.
Posted on Sep 21, 2007
  • 374 Answers
SOURCE: have dish receiver 510, channels i need are on
Donna,
I am sorry to hear of your troubles. I am assuming you have another receiver in the house that is an HD receiver as the 510 is not and it would not make any sense for you to have the 129 orbital without it. If you go to the other receiver and are able to get transponder 21 on the 129 bird then the issue lies in either the cabling, connectors, barrels and or wall plate, or the 510 itself. Assuming you were good to go with the hi def receiver move it to the 510 location and see if you are able to still p/u the 21 transponder. If so, the 510 is bad and needs to be replaced. If not the problem lies in the aforementioned areas. if yoou are unable to get the 21 transponder on the hi def receiver also then more than likely the dish needs to be repeaked. If I can be of more assistance let me know. Thanks for using Fix Ya.
Posted on Feb 23, 2009
jdn74
  • 35 Answers
SOURCE: Have Direct TV using a Sony Digital Satellite
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Posted on Mar 26, 2009
MNfisherman
  • 11896 Answers
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Posted on Jun 22, 2009
Can’t get from analogue to digital on my Panasonic viera tv
Have you done a channel scan? This can take a few minutes but it locates and lists all channels If you've not done this already, go into your menu, channels and be sure to enter the receiving input whether it's antenna,cable, or satellite, start your scan and see what channels you're receiving. I sure hope this helps and good luck
Nov 28, 2017 | Panasonic Televison & Video
My new sony does not find channels during auto scan. All hdmi connected properly
Auto scan is for Terrestrial broadcast RF Signal Analogue or digital.
For HDMI inputs, you need to tune your satellite receiver or similar
Nov 01, 2017 | Sony Televison & Video
My channel list is empty. How do I manually add channels. NOT ACTUALLY SCAN.
First you have to connect your source of channels to the television via a receiver, whether satellite or cable, or 'free to air'. Then you instruct your television to scan for all of the channels. Then after that, you can either choose (say) channel 1432 on the remote, or scan upwards from channel 1000, or set it as a favourite.
It sounds to me that you have nothing connected to the television, or the supplier of the signal (the receiver) is switched off :>)
Dec 04, 2016 | Televison & Video
Fuba ode 582/592 no scan possible
Check and replace its tuner. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 07, 2014 | Televison & Video
How to get the right input for a conventional rca tv
Channel 3 is what you want anyways if you use the co-axial for the input. You can't have any other channels until you do a scan and there are no other channels anyways when you are using the tv as a monitor. So all your problems exist before that. Since the tuner is analogue and the satellite receiver is digital you may need a modern brown box.
Nov 28, 2013 | RCA F27242GY 27" TV
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
No digital channels when scanning.
Do you remember to swith between cable and air in the set up manu? It needs to be at air position to have full scanning.
Aug 18, 2009 | Vizio L32 32 in. LCD HDTV
My LXI TV won't allow me to get any channels above 13 after doing the auto scan for channels. I am using DirectTV.
The only way to fix the problem is to hook your TV to a standard cable hookup and go through the "auto memo" scan process. The auto scan progarm then automatically sets itself to the CATV mode, rather than the standard mode, so channels above 13 can be received after disconnecting and reconnecting to a DirectTV, satellite antenna.
Aug 29, 2008 | Televison & Video
Satellite receiver
dont need factory to reflash.
turn of set at plug.press and hold backup on set(keep pressed)
turn on at plug.keep backup pressed for about 15 seconds.all lights on set will flash.if you have tv tuned to set screen will display updating system.dont turn off.when lights on set go off(about 10min later)set is reset(flashed)Press power on remote sky will restart like new.
Sep 03, 2007 | Panasonic CR-SRF100 SIRIUS Radio Receiver
Televison & Video Logo
231 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
