Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mower won't move in forward or reverse, it just makes a loud wining noise. I've had this happen before but I usually can get it moving.
  • 760 Answers
If this is a hydrostatic drive. Check oil level in transmission. If you have been running it low on oil, it may be too late for the hydrostatic drive unit. If it has a drain plug, drain it and change the oil.
Posted on Jul 18, 2010
My JD L130 has little power going foreard and almost none in reverse.
The forward reverse pedal linkage needs adjustment. Remove mower deck pins and slide out of the way. Pull linkage pin out then turn clockwise one full turn .move brake pedal while looking at it .You should see a small brake disc on side of rearend with a nut bolt going through the disc. Pull rod on back of mower that allows you to push mower freely.set parking brake try to move mower by pushing if it moves with break set tighten bolt that goes through brake disc til mower don't move.release parking brake try to move mower should roll easy.if not losen bolt 1/2 turn til it moves easy.reengauge rod on rear of mower to drive it test and be sure to place cable ties on any thing under mower dragging ground .If test works .reinstall mower deck.
May 18, 2014 | John Deere L100 Series
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
97 wrangler wont drive forward in 2wd. just makes a loud grinding noise but will drive in reverse
sounds like rear end is coming apart
google wrangler forums and post there
Feb 03, 2013 | 1997 Jeep Wrangler
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Is it advised to move the wine bottles every once in a while?
If it is possible, don't move the wine at all from the moment you've started storing them. You should store the wine in your wine rack in a way that you won't have to move any other bottle in order to get to the desired one.
Aug 13, 2012 | Furniture
John deere x340 wont move
there is a release usually behind the seat that has to be pulled in order to push it physically. make sure that the release is pushed in for the forward/reverse to work.
May 26, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
925 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
