Question about Friedrich CP12C10 Wall/Window Air Conditioner
It is kind of smoky looking has no smell and comes out with the air especially when the ac is on high speed
  • Friedrich Master
  • 43,501 Answers
This can happen when the temperatures and humidity are just right...saw it in the cockpit of the airplane I just flew on the other day...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
What smell comes from an air conditioner leaking freon?
More then like no. Your AC does not hold very much freon so anything other then an extremly small leak would cause it to stop working. It is probably some small rodent or something like that got into your AC and passed.
Jul 23, 2014 | Heating & Cooling
Does my 2009 ford explorer have a cabin air filter?
I don't list a cabin filter available for 2007 - 2009 Explorer.
Usually the smell is trapped water in the hvac box due to a plugged drain line. The water is supposed to drain onto the ground under the truck when the ac is on.
Jul 29, 2013 | 2009 Ford Explorer
Circuit unit behind the ac controls
sounds like your blower motor has stopped working check for power going to the blower system if you have power the blower is probably bad the concern is the lack of a fuse blowing or a breaker not cycling you may have a harness problem sometimes a low grade short will heat up wires then melt them together causing a multisystem failure even though a fuse or breaker didn't blow check you harness
Aug 09, 2012 | Dodge Avenger Cars & Trucks
Bad smell coming from vents in my 2002 silhouette
did you change your hepa filter? Buy ozium and spray in your vents.
Jun 03, 2012 | 2002 Oldsmobile Silhouette
98 silverado ac blower only blows on high after it froze up after ice storm /motor or switch bad?
Sounds like the resistor pack on the heater case needs replacing. That's how you get lower motor speeds. Unplug it, remove it, and look for broken wires on the little pack. Some water or ice probably got around it and ruined it, giving you that smell of burning wires. Ice and water must have come through outside air recirculation passage.
Dec 05, 2011 | Cars & Trucks
When starting each time get a really awful smell [like old urine thro the air conditioning] is it filters or need re servicing
Depending on the year it may have a filter. i would check and replace it, another thing ive found on many cars is that mice make nests on top of the filter for the heating/ac system and that smells bad, what i do is replace the filter and then turn on the ac or heat at low temp with high speed fan and make sure the setting is for outside air not recirculating and then spray grem and ordor killing spray into the vents, not inside the car but from the outside where the wipers are, this is where the air comes in from and also make sure to open door to allow the spray to exit the car, good day.
May 28, 2011 | Saab 9 3 Cars & Trucks
Fan is making clunking sound like it is hitting something.
Yes, it certainly can be, especially in high humidity. Run AC just about 1/4 way from max and crack the windows. The ac will work better and ice up less.
Jul 29, 2009 | Fedders U Chassis A7U12W2A Air Conditioner
Blower doesn't work at high speed
you will need to replace the fans blower resistor. its mounted in the cab. in the lower right side of the heater box. some aftermarket suppliers are carrying the part but all chevy or gmc dealers will have it.
good luck chris
Mar 15, 2009 | 2003 GMC Envoy Xl
GE spacemaker xl1800 microwave "burnt paper" smell
Hey
There are several things you can do to help git rid of that smell
First get a mild cleaner with bleach (soft scrub ect!) and clean entire oven inside and try getting that scorch mark off! a little pressure should lessen it ! (there is no filter inside! The plastic inside covering holds smells for a long time! you can also put a cup of white vinigar inside warm on high for 1 minute and leave in overnight!
Please take a second and rate my response
Thank You1
Jan 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My subwoofer smells smoky and there's a humming sound..
Well,
It best to call the manufacturer to get the speaker system replaced. As you see it smell bad , could be a burnt fuse at the back of the sub.
Apr 14, 2008 | Dell ADA745 Computer Speakers
Friedrich CP12C10 Wall/Window Air Conditioner Logo
110 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Dennis Boxerman
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
