Question about Panasonic Microwave Ovens
Panasonic NN-C703 replacement light
I have a Panasonic Dimension 4 Microwave/Combination Oven NN-C703/NN-C753 that needs a new light bulb. Can I do this myself?
SOURCE: Panasonic Dimension 4 the Genius
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
Posted on May 26, 2008
SOURCE: Panasonic Dimension 4 Turbo Bake
Your Magnatron is most likely to have failed, its an expensive part and on a turbo 4 could be 2M236-M42. Unfortunatly this appears to fail due to reduced air flow. So if you do replace it I would clean the rear grills completely to increase the airflow within the oven.
Posted on Aug 23, 2008
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic NN-P295 Cooktop Light not working
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jan 23, 2009
SOURCE: Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
Posted on Aug 27, 2009
Testimonial: "Hi - and thanks Martin for an excellent description of the process. Perfect assistance for a handyman-challenged guy like me. Thanks Grant"
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Need user manual for National model no: NN-8655 Microwave oven user manual...
I would suggest that contact the dealer from whom you purchased the oven or call any number listed on the model tag of the oven.
Jan 06, 2014 | Panasonic Microwave Ovens
Dimension 4
I have this NN-C780P Microwave/Convection Oven. The microwave mode is not working and baking was ok until recently, the turntable cannot rotate when the temperature, timing and baking are ok.
When I bake, there are knocking sound.
Please advise.
Sep 10, 2013 | Panasonic NN-T888S Convection/Microwave...
Need a new light bulb
you can purchase new light bulb for your microwave oven at ebay.com
May 03, 2012 | Panasonic NN-S550WF Microwave Oven
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Cook top light will not turn off on Panasonic Microwave nns255
Check your manual and see if you purchased the correct type of replacement bulb (wattage).
Apr 25, 2009 | Panasonic NN-P295SF Microwave Oven
Have a Panasonic Micro nn-T790 SA, need to replace light???
If you don't see an access panel inside the oven, you must remove the outer cover to find & replace the bulb. Be sure to unplug the oven first!
Many models use halogen lamps. You must not touch the new one with your bare skin as the oils will shorten the bulb life.
If you don't have your owner's manual, you can download it here: http://service.us.panasonic.com/OPERMANPDF/NNT990SA.PDF
We're happy to help and we appreciate your thoughtful rating of our answer.
May 17, 2008 | Panasonic NN-T790SA Microwave Oven
Panasonic Dimension 4 the Genius Microwave/Convection NN-C888W I cannot seem to get into this to replace the electric light bulb. Please can you help me.
AH
Apr 30, 2008 | Microwave Ovens
Panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Microwave Ovens Logo
174 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
