I have triton opal shower, low pressure light used to come on intermittantly and the water would go cold, but its now on all the time. water pressure seems fine even from the shower head. have you any ideas please.
  • Anonymous Mar 09, 2009
    Exactly the same problem. Checked pressure sqitch on PCB and it seems fine.
  • kelvine20 Mar 30, 2009
    I have a triton opal shower & low pressure light was coming on intermitantly & water goes cold, but now its on all the time, water cold, but got plenty of water pressure, can you help.
  • 101 Answers
Try to replace Pressure switch for water fill level that is locate at the top under the lid.
Posted on Apr 21, 2008
I have a problem with my triton shower.i use this shower for 9 months everything was ok but now to get warm water I have to turn the dial to 9 or 10 and it just a little warm and the pressure is very...
Since I am unsure of the model you are using I would suggest you go to their site and check the FAQ's and support information. You can select your info in the drop down boxes and go from there:
FAQ Triton Showers for the Homeowner
I hope this helps.
Jan 29, 2015 | Home
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
Triton t300si shower low pressure problem
there is a fine inlet filter on the plastic pipe,remove and wash under tap pressure
Feb 26, 2013 | Home
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
My triton martinique electric shower low pressure light comes on and the water goes cold but there is nothing wrong with the pressure
how on earth is this related to gaming consoles or PS3 ??
Please post under correct sections next time.
Anyways, it looks like a common problem for the Triton Shower, and it might cost you some $90 to fix it.
http://www.comparestoreprices.co.uk/showers/triton-martinique-10-5kw.asp
Sep 07, 2009 | Sony Playstation 3 (PS3) Console
Triton opal shower showing low pressure,when there is no low pressure!
In the top of the water inlet valve at the bottom of the unit there's a plunger that rises when the water is switched on. this activates a small switch at the bottom of the pcb and cancels the low pressure warning. this is free to turn in the valve and over times may rotate stopping the plate on the top from contacting the switch on the pcb. If this has happened just turn the plunger back to the correct position.
Aug 28, 2009 | Water Heaters
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Washing Machines Logo
790 people viewed this question
Top Washing Machines Experts
