Question about Motorola Mobility H700 Wireless Headset
Pairing h700 to sanyo s1
After pairing h700 with sanyo s1 cell phone (purple light stays on during pairing) phone says "found list" but h700 does not flash blue and does not work.
    Scholar:
  • 125 Answers
After your phone has found the H700 you have to tell your phone to pair with it. It will then ask for the code. Punch in 0000 and confirm. After a little bit the H700 will flash blue several times rapidly and then start blinking about every 5 or 6 seconds. It is then paired with your phone.
Posted on Jul 13, 2008
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
How do i enter pairing mode motorola h700
While the mic is still folded in, press the big phone button until the light turns purple. When it does, unfold the headset and the device should be in pairing mode (the light should STAY purple)
Mar 07, 2011 | Motorola Mobility H700 Wireless Headset
Pairing bluetooth with cell phone
I solved this problem myself. Thanks for allowing me to post anyway. Nice to have a backup plan. First I had the wrong bluetooth listed it is actually H700 not H710. And to get it in pairing mode you press the call button and hold it while opening the boom and the purple light stays lit then it is ready for your phone to search and find it. Very simple really. Makes a person feel rather stupid when you realize how easy it really is. Thanks again for having a site for dumbies like me.
Dec 16, 2008 | Sanyo SCP-3200 Cellular Phone
Using h700 as a PC headset
Rjcroller wrote and is working fine. please follow....
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jul 16, 2008 | Motorola Mobility H700 Wireless Headset
Purple light will not stay lit
I signed up JUST because this solution worked:
"Hmm this may sound like a stupid solution that doesnt work but what i did is...,
#1 I Held the button to make the violet light go on
#2 when the violet light is on dont just flip the boom mic, flip* the earpiece with it.
*note: when fliping the mic and earpiece, dont open slowly, flip it open fast and keep it there." I do want to note that my passcode was reset to nothing during my 3 months of troubleshooting.
Not going to mess with it.
Mar 26, 2008 | Motorola Mobility H700 Wireless Headset
Purple light wont stay lit for pairing
Make sure the microphone is closed and the BlueTooth is off. Hold the button in until it turns purple. As soon as it does release the button and flip out the microphone. The purple light should stay lit all the time now. That is until the pairing process is done with the phone.
Mar 18, 2008 | Motorola Mobility H700 Wireless Headset
TRYING TO PAIR THE H700 TO MY TMOBILE WING
Just have to re-pair it.With the H700 BT headsets the pairing mode is different from other BT headsets. to put it in pairing mode you first hold the talk button on the headset until the purple light comes on.Right after the purple light comes on you have to flip open the headset for it to stay in pairing mode. From there you continue through the phone. It will ask for a password; that will be "0000". then connect.
Jan 28, 2008 | Motorola Mobility H700 Wireless Headset
Pairing
The same way you did to your Razr. Make sure the H700s microphone are is in the off position. Push in and hold the button on the H700 until the light lights up purple. Release the button and quickly open the microphone button. The light will stay purple and you are now in "Pairing Mode". Now follow the instructions for your phone to pair with a BlueTooth unit. When it asks for a code, use 0000 (that is 4 zeros).
Oct 26, 2007 | Motorola Mobility H700 Wireless Headset
How to do pairing
Thank you. I called a 1-800 number for tech support but they told me I had to wait 14 days from the date of purchase before they could help me. Your suggestion was right on the money. Thank you.
Jul 18, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Apr 30, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
101 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
